Samsung SyncMaster 740N 17" LCD Monitor Logo
A
Anonymous Posted on Jun 13, 2014
Transformer circuit diagram L9ZA-A1
Specification of components
Nilanjan Pathirana
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Sep 04, 2016
Nilanjan Pathirana
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
10330
Points
45
Http://www.eserviceinfo.com/index.php?what=search2&searchstring=fujitsu+siemens+L9ZA+lcd+monitor
2answers
Looking for circuit diagram for Dixon Power Mixer TMS 8?
This appears to be a South African unit? See if the link works better for you. An electronics technician could fix by component testing and by knowing how to wire a transformer (high voltage windings and low voltage windings).
https://www.google.com/search?q=dixon+power+mixer+tms+8+wiring+diagram
2helpful
2answers
I'm looking for a transformer replacement for my Reznor Unit Heater XL30-5. Transformer # 050674 not found.
If a company has the facility to wind their own transformers, they will probably find it possible to wind to their exclusive or special specification while saving cost but when production ceases it can be difficult to replace from a generic catalogue - but if the transformer was a bought-in component the chances are good there will be a catalogue of generic transformers, one or more of which will meet the required specification.
In the case of a special specification it might be necessary to fit more than one generic transformer to perform the function of the original. I have seen several machines and appliances where an enterprising engineer has faced that problem and had overcome it by fitting two or three transformers in place of the original.
All you need is the specification and that should be provided by the service literature, a service engineer or by very nicely asking the company...
1helpful
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
1helpful
2answers
Where to get clear diagram of magnetron circuitry with capacitor and diode circuits shown ?
Below is a common diagram for LG Microwave "High Side" components.
The component below the Monitor Interlock Switch is the Transformer. So, on the High Side of the transformer, you can see all the components.
Can you give me the model number of the unit that you are wanting information?
2helpful
2answers
What are passive circuit components?
they are modules that don't require power to run, aside from the power source the circuit is connected to. These modules don't generate or hold power but they are able to amplify power, a transformer is an example of a passive circuit component.
Why won't my Canon XH A1 power up
The most likely cause is a component failure in the power circuit. This can be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be looked at by a qualified technician. Here is a link to a repair shop that should be able to help you.
www.discountcamerarepair.com
1helpful
2answers
Problem
There is no "Flyback transformer" in the LCD monitor "Benq 17" model No. Q7T3". Such a component, a "Flyback transformer" is found in televisions and in Picture Tube type monitors. The red wire of a "Flyback transformer" is where 27,000 VOLTS comes out of to connect to the picture and such a voltage IS DEADLY so never enter a TV or computer monitor unless you know exactly what you're doing. To bring your hand too close to the "Flyback transformer" is to GET ZAPPED, you don't even have to TOUCH that transformer or the Red Wire that comes out of it!!!!
As far as a fuse blowing, NEVER PUT IN A FUSE WITH A HIGHER AMPERAGE RATING: it's there to protect certain components from being permanently damaged. If the fuse is blowing you must find out "why". There's got to be a short circuit in one or more components. Transistors, Diodes and Capacitors are easy to check for shorts. Transistors, Diodes are usually what short out. There's not much more I can say here.
A schematic diagram that shows the voltage on the many components of a running LCD circuit is what you need to find out where volatges should be. If a voltage is missing you must find out where the problem stems from. There are other ways to test circuitry, with an oscillascope and a schematic diagram that shows test points and the wave pattern that's suppose to be present.
Is it possible to use the transformer when using DiMAGE A1 abroad?
Here are trans transformer and electric transformer (small model is mainly for overseas travel). There is no problem when using trans transformer, however when using electric transformer, there are many models which cannot be used with battery charger, precision instruments and so on.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
