SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Your pump/filter is plugged. (E4) There
is a round door on the lower front of the washer. There is a small hole near
the door. Put a small screwdriver blade in the hole, push in just a little, and
you can rotate the door clockwise, the door will come out and you can get to
the problem. When the water is drained
in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter.
When you unscrew this, all the water left in the washer will spill out onto the
floor. Use a plastic bag to catch this or a small pan.(later models have a
drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find
the source of your clog. Remove it, clean out, screw the black connector back
in. You can check with rinse, if you
want to make sure there are no leaks. Put
the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
