GE APN08AA Portable Room Air Conditioner Logo
Question about GE APN08AA Portable Room Air Conditioner
HOW TO CLEAN THE DRAIN PAN ON A GE WINDOW AIR CONDITIONER
william simpson
    Genius:
  • GE Master
  • 1,363 Answers
You have to remove it from wall & wash coil with hose add a little bleach to pan.
Posted on Sep 05, 2015
5 Related Answers
Anonymous
  • 16 Answers
SOURCE: GE air conditioner
what type of unit is it, window ect?
Posted on Jun 07, 2007
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: GE air conditioner ASM08LLS1 Problem: Cannot
if its in a window make sure no one put a screw on the outside when mounting it.
it takes 2 to pull one out sometimes as the water ,goop ,rust gets under the tray.
I assume you removed the front.
the base pan is all you can really pull on hard but you can do some pulling on the sides just be gentle. lol.
Posted on Jun 13, 2008
Donni Steen
  • 687 Answers
SOURCE: wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Posted on Apr 01, 2009
Anonymous
  • 308 Answers
SOURCE: where is the air filter for a GE deluxe 26 wall
It can be found behind the front grill of the unit, and it is a washable filter. For more info follow this link
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=AGM24DJ
Hope this helps
Posted on Aug 11, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my ge window air conditioner
On many of the newer air conditioners they intentionally keep some water in there so that it splashes onto the condenser coil and helps to cool it....while this may work well it also creates more noise....so I often recommend to drill a drain hole in the back corner...jus drill down from the top...drilling up from the bottom is a great way to drill right through the coil....
heatman101
Posted on Sep 01, 2010
My GE window unit air conditioner isn't blowing out very cool air,and it spits what
From what you have described, it sounds like the drip pan under the unit is full of water. This can be caused by the unit not being installed properly in the window. It must have 1/4' to 1/2" downward tilt at the rear. This allows the water in the drip pan, to flow to the rear and drain away thru the drain hole. Also, the drain hole may be clogged and needs to be cleared. The drain hole can be a challenge to find sometimes, as the clog can blend in with the hole. Be patient and persistent when looking for the drain hole. A pipe cleaner can be used to clear it.
I hope this helps and thanks for choosing FixYa.
My window air conditoner is leaking water inside and what can I do to prevent that?
Make sure the unit is tilted down at the rear at least 1/4" to 1/2" and that the drain hole in the drain pan, under the rear of the unit is not clogged. The drain hole can be hard to find, as clogs blend in with hole. So, be persistent in looking for it.
Hope this helped you Elaine. Thanks for choosing FixYa.
Had my air conditioner in the window for a few months and now the water is spraying out at the front on the bottom help
This usually caused by high humidity and a build up in the condensation pan under the unit. Or the drain pan has a clog it's drain In addition, if the outside part of the unit is not sloped (tilted) down 1/2", to allow the water to run to the back of the pan it builds up under the front of the unit.
A6K32E7C part number for kit to keep water from blowing out thru the evaporator
you may just need to pull the unit out and clean the small drain pipe that goes from the evap pan its the pan under the front coil and should drain toward the back of the a/c toward the condensor coil ..the coil on the back of the unit
Have a GE window air conditioner that froze up Ithawed it out and is working normal. It does not seem to drain dont actually see a hole is that normal?
They usually carry some water in the pan andd the hole will be in one of the outside corners... they can be a bugger to find sometimes and I have drilled new ones already... just make sure not to drill the coil... :-)
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
2helpful
My GE air conditionar doesnt drain any water, I have it tilted whats the issue
Often dust and dirt will plug up the hole in the bottom pan...and keep the water from running out...
heatman101
2helpful
New air conditioner not working P1 error
Check float for drain pan is not taped up for shipping, and remove whatever is holding it up & let it drop down, into pan.
Not draining
It has to be angled slightly toward the back to the pan under the bck coils and out to the outside, good clean water great for plants and pets.
4answers
Goldstar Air conditioner
Tilt the unit toward the window opening and clear the drain holes in the back and bottom of the unit from debris.
Top GE Heating & Cooling Experts
ray gallant
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
