Question about Jacuzzi Home
Circ pump not operating on my jucuzzi J345 hot tub
Error code FL1 flashing. New heater. flo switch appears ok
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: New World DW60 dishwasher not
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
Anonymous
  • 4 Answers
SOURCE: hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
Anonymous
  • 125 Answers
SOURCE: Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Posted on Feb 24, 2009
Anonymous
SOURCE: SDW60 - AL08 Error - No Hot Water
Hi fridge-1,
I had the same problem and fixed it by fitting a new control board .
Best of luck.
michael-howe
Posted on May 16, 2009
Anonymous
  • 10 Answers
SOURCE: code FL1
hi, this generally means a flow error and shows when the heater is looking to heat but there isn't enough pressure running through the heater tube. in this case the thermal overload sounds like it has tripped in the pump.
Posted on Jul 08, 2009
I installed a new heat sensor in a jandy pool heater. It is still flashing an FL1 code.
Sounds like you have an LJ Laars heater. The heater is old and it is very likely that the board is having trouble reading the sensor. All the boards are very expensive, might not be worth saving the heater. You may end up replacing more than one board. The sensor should be tested before changing the power control board, R0366800.
Mar 14, 2017 | Jandy Pool & Spa
LAARS LX250N-L error code AIR FLO SW and sometimes a HI LIM SW cannot locate the source of the problem?
hi limits are located under where the pipes go into the heater if corroded replace if wires bad replace to test you can jump them at the board only testing if left jumped heater could catch fire
Jun 29, 2015 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Jacuzzi j355 hot tub FL1 code flashing on control panel
sounds like the recirculation pump isnt working FL1 means no Flow pump 1
Aug 24, 2014 | Jacuzzi Pool & Spa
FL1 fault code
Definition of FL1 = Water flow problem, inhibited or pressure switch malfunction. Check for proper spa water level and ensure pump is primed. Check for clogged filter.
Its likely to be your pressure switch (screws into heater tube, usually two wires) If this is blocked or has failed the heater will not turn on.
Jul 18, 2012 | Dream Maker Spas Pool & Spa
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
Getting error message FL1 on face plate
check filters then pressure switch then copper tube going to pressure switch
Sep 04, 2011 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Filled artic spa 36 hours ago. not heating properly. what should I check?
If you don't have any error codes, FLO, FLC, then there is a chance your heater has burnt out. You would need an Ohm meter to measure if you have continuity thru the heater element. You should read 11 to 12 ohms. If you have either FLO or FLC on the display this indicates a problem with the pressure switch. The pressure switch is threaded into the side of the heater, the stainless steel tube attached to the #1 or main pump. Its a round module with two wires attached to it. There is an adjusting post in the center of the module. For an FLO code turn the post half a turn CCW. For an FLC code turn it half a turn CW. If this does not solve the problem replace the pressure switch.
Oct 16, 2010 | Arctic Pool & Spa
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Code FL1
Jun 06, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Heater will not light off
Be sure filter not dirty or too old lack of flo can cause tripping of high heat switch check flo switch also always check simple things 1st traceace
Dec 20, 2008 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Home Logo
69 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
