Question about HP Photosmart C6180 All-In-One InkJet Printer
My printer keeps saying wrong cartridge but they are the right ones
aryaan khan
    New Friend:
  • 3 Answers
Which things we should check when we purchase a use laptop ???
Posted on Feb 28, 2019
Harsh
    New Friend:
  • 17 Answers
Use a lcd cleaning liquid to clean the head of cartridge then insert them in your printer and then press the power button for 5-10 sec then on the printer it should work!!
warning it can even damage proceede at your own risk!!
Posted on Jun 13, 2014
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: NEED HELP WITH MY PRINTER
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution: http://www.whatmobile.com.pk/hp/hp1210.htm
Posted on Aug 05, 2007
Anonymous
  • 214 Answers
SOURCE: printer Align keeps failing after I chnaged the color cartridge
Are all the inks printing? If not you need to get all colours working before correct align can take place Have you tried cleaning the gold cartridge contacts? Wth a little distilled water, cotton bud and then let dry before reinstalling
Posted on May 29, 2009
Anonymous
  • 214 Answers
SOURCE: printer says reve and check cartridge on right. This is right after I replaced with refilled cartridges
Try this link www.uni-kit.com
Anonymous
SOURCE: HP c6280 Won't load ink cartridges
Per HP:
Hold “print photos” button and “red-eye removal” buttons together, release
ø Then press the “red-eye removal” button, release
ø Then press the “print photos” button, release
ø Then press “red-eye removal, release
ø Scroll to “resets menu”, click ok to select
ø Scroll to “Options” semi-full reset, ok
The printer then powers off and wait a couple of minutes. I believe the printer turns back on (or maybe the user needs to power back on after a few minutes). The refills then work.
Posted on Jul 03, 2009
Anonymous
  • 677 Answers
SOURCE: remove and check cartridge in right stall help
Make sure that they are new cartridges.
Also make sure, that you took off the strip off where the ink come out.
Then shut if off, wait 15 min, then turn back on.
Good Luck
Posted on Nov 04, 2009
Keeps saying my colour cartridge is missing
Problem
Wrong cartridge; Left cartridge incorrect; Right cartridge incorrect; Left cartridge missing; Right cartridge missing; Error 1205; Error 1206; Cartridge error; Cartridge incorrect; Cartridge missing
Environment
Microsoft Windows XP; Microsoft Windows XP Professional x64 Edition; Microsoft Windows 2000; Microsoft Windows Vista
Solution
Explanation
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
    • The wrong cartridge is installed, or
    • The cartridge is not installed properly, or
    • The cartridge is missing.
What to do
X4850
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
Feb 12, 2018 | Lexmark X5270 All-In-One InkJet Printer
Display keeps saying check cartridge on the right i check keeps saying it put a new cartridge in still says same thing photosmart 2610
You could be getting this problem if using refilled inkjet cartridge. Try replacing cartridge and see if message clears.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
Printer keeps saying remove cartridge on the right
i have this problem to.. will try to reset it and resend
Mar 29, 2010 | HP PhotoSmart C4180 All-in-One Color...
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
The window says that the wrong ink cartridge is installed and when I remove it and replace it it says remove and replace cartridge. I have put 2 new cartridges in and they are the right ones. It will not...
sometimes when replacing ink cartridges some idiot that filled them to begin with doesnt reset the calibration they just shove the ink in and box em up!!
its not your printer its who you bought the ink from
Jan 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Replaced color cartridge...alignment keeps failing. On alignment printout, yellow and blue are not printing. It's a new cartridge and it keeps saying "Check color cartridge"
You should first check and make sure it is the correct cartridge, and was not packaged wrong(know this because it happened to me a year ago wrong cartridge in package). If it is right check and clean your conntacts and reinstall. It may be a defective cartridge or the jet contacts are not working on the cartridge. If it still does not work take it back and get a replacement telling them it is defective. Then try again making ure contacts are clean on printer also. Good luck. Any problems leave a comment and I'll get back to you.
Oct 27, 2009 | HP PSC 950 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Canon printer
a) Verify the right color cartridge is in the right slot.
b) Verify that the cartridge is fully inserted (Press on front of cartridge) top gently to ensure the "Electrical" contacts make good contact.
c) Turn printer off/on
Feb 09, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
Ekse
efs_perpends
efs_perpends
