Onkyo TX-910 Receiver Logo
A
Anonymous Posted on Jun 12, 2014
How do i reset my startrack receiver?
I am not getting any reception on my receiver. Pls help?
Tv programs freeze up numerous times during day. have to unplug, retart each time. what can be done? I HAVE VIP 222K MODEL.
There is an installation problem, and you need a technician. When the receiver reboots, it sends a boost of power to the LNBF until it gets a signal in return, or gets a response of no signal. If you have damaged lines, a damaged receiver, damaged LNBF, or low signal reception on your antenna, a rebooted receiver will, for a very short time, boost the signal enough to get reception. Then, the receiver will drop the power back to the correct levels, thereby eliminating the short term reception boost. A technician can repair your installation to improve the reception, as long as there is Line Of Sight to the correct satellites.
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Can a toshiba 28z07b be digitally tuned
Your TV set has a 181 Channel Tuner and 100 Programme Positions..
Over the air signals (analog and digital) are free but require an special antennas for Digital reception and reception depends on your where you live and other factors.
Additionally Cable and satellite signals require you to connect a cable to your
TV tuner and a subscription and cable box for premium channels including Digital channels..
While all l TV tuners have the ability to receive over the air TV signals,
not all tuners can receive high definition (HD) signals. In North America, all
over-the-air TV is now broadcast in digital quality (ATSC).
ATSC is the over the air HDTV standard for North America and is currently available
in over 200 cities in the United States.
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
I have lost digital reception. I can play DVDs and get analogue TV.
You need to make sure your reception is strong enough to receive digital reception otherwise you will only receive analogue reception and dvd playback ability is normally nothing to do with the TV's reception.
Ensure you have strong reception before doing an auto tune to search for the channels. Good luck.
I use it for work so i need help asap... my garmin nuvi 205w when i first turn it on it sais poor satilite reception but the voice sais lost satilite reception or connection idk witch... but its been 24...
there is a reset button on your garmin. carefully pry off the frame around the screen with your fingernail. Under there you will see the reset button. push it and then see if your problem is solved.
Voice activation capabilities locked and none functioning after driving for 2 hours or so. Satellite reception getting lost even on a sunny day
I can help you reset and fix your Garmin Nuvi 265W.
Erratic behavior and improved satellite reception has been addressed in new system software / firmware update.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Can't get reception. Unplugged everything...EVERYTHING...including dish..reconnected, cleaned card and in dish pointing cannot regardless of respondent, cannot get reception HELP
Getting reception for you is not something we can conjure up. Therew could be a million resons why u cant get reception including a damaged TV receiver or a damaged Disk receiver, broken coax etc etc etc.
You can buy a meter that connects in line between the dish and the Tv that will measure any signal being received for about $20. But is no guarantee that the TV is not faulty even if you see a good signal on the display.
Often better to engage a Tech on site than fall off the roof and become a para or electocute yourself playing around inside the TV.
Life is more valuable than saving a few bucks on a tech!
AM and FM get no reception, why?
pls check you antenna connection
Need to do a manuel reset
Unplug receiver for at least 1 minute.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
