Hoshizaki Commercial Freezer KM-500MAH Logo
A
Anonymous Posted on Jun 12, 2014
Wherehis alarm reset button? - Hoshizaki Commercial Freezer KM-500MAH
Dennis Boxerman
Level 3:
  • Hoshizaki Master 1,306 Answers
  • Posted on Sep 13, 2015
Dennis Boxerman
Hoshizaki Master
Level 3:
Answers
1306
Questions
Helped
646532
Points
2787
KM says this is an ice maker. Reset button is on the control board. Board is in compartment on the right side where the power switch is located. Remove 2 screws and remove cover by sliding forward. Watch for wires, do this carefully. On the board, up at the top, is a small, white button. With power on, push the button.
2answers
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
I do have a upright whurlpool freezer. The alarm light comes on. I reset the alarm but the light is still flickering. How do i reset the the whole thing.
If you are rearranging the things in the compartments this can cause the alarm to stay on: it depends if the door is open a long time.
My freezer has an alarm button to deactivate the alarm for this purpose.
Have you still got the user manual that came with your freezer?
If it is possible to deactivate the alarm, it will tell you how.
Oct 08, 2018 • Freezers
My AEG freezer alarming light flashing followed instructions pressed button and light flashing left hours and alarm light still flashing.
If the alarm light on your AEG freezer is still flashing after you have followed the instructions and pressed the button, it may indicate a problem with the freezer. You can try unplugging the freezer and leaving it unplugged for a few minutes, then plugging it back in to see if the alarm light resets. If the alarm light continues to flash, you may need to consult the manual or contact AEG customer service for further assistance.
May 27, 2018 • Freezers
I have the GLFU1467FW0 model Frigidaire freezer, and the temperature alarm won't stop going off. How do I flip it off for good? Pressing the alarm reset button does nothing.
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Where is the alarm reset button for KM501 MWH
Look for a small button on the control board. just press it to reset.
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Electricity went out & audible alarm is going off. Would like to know if there is a reset button for this or will it reset itself when temp goes back to normal.
Will stop on it's own when it get cold again, but most generally have a manual alarm shut off (on back, near hinge on older models).
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
9helpful
Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
THE ALARM LIGHT HAS COME ON HOW DO I RESET THE ALARM AS I DONT HAVE A MANUAL TALL FREEZER FVE 1415 FREEZER TRIPPED OUT ALL FOOD NOW LOST
When it is fixed and the temperature goes back down it will automatically go off.
If it's stuck trying unplugging for 10 minutes and then plug back in to reset. If it has a battery backup take out battery.
Inside the door near top there is sometimes instructions to hold the button for 3 seconds to reset or unlock controls (on modern Frigidaires and some Kenmores).
Top Hoshizaki Freezers Experts
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Steve Pack
Steve Pack
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
