Johnson 7.5 hp 1956 model AD-10M shifter wont go into forward
I have a 1956 Johnson 7.5 hp outboard model AD-10M it shifts into reverse but wont go in to forward. feels like the shifter is hitting something or the rod is bent.
What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
you have removed the leg to replace the water pump impeller
the leg has the selector rod for the forward and reverse action
as the direction selection is a simple dog that moves forward or back to connect the spur gears and it was working before you pulled the leg off , then I am thinking that when the leg was reassembled that the selector was in a wrong position and now you are only moving it in one direction neutral or reverse instead of the 3 positions forward neutral reverse
nothing else can change except where the rod connects in the leg
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
