Question about Thunderbird ARM-01 Planetary Mixer
Where do I drain the oil in a 60qt. thunderbird mixer
Where is the drain plug?
Posted by Commercial Food... on
Joel Friedenberg
    Genius:
  • 1,114 Answers
If you are referring to the transmission, I believe it's a sealed unit.
  • 3-Speed gear box
  • Transmission: Wide-faced, hardened alloy steel, helical gears fully sealed in transmission lubricant with heavy-duty ball bearings and clutch combine for highly dependable, quiet operation.
  • Posted on Jun 13, 2014
    Testimonial: "Yes I was deferring to the Trans. The oil still needs to be changed, as the sticker on the side says, every year. My question is how do you get the OLD oil out of the sealed trans."
    My Hobart grinder is old vintage it has 3 or 4 oil ports do I still use Mobil DTE HM OIL? How much in each port?
    Steve I dont know that that is necessary. I have 2 a big heavy monster and a little #12 and I check for full and keep going. I only use mine in winter for sausage and its 50# in 120 sec. not much wear and tear on the lube. I know Hobart has a good web and mobile service here. Mine are Old and I'm guessing yours are too.
    http://www.hobartcorp.com/
    Jan 10, 2016 | Hobart Food Mixers
    Left my honda petrol cement mixer upside down and now it won't start. How to I get it to work again?
    There is probably oil in the cylinder. Remove spark plug drain oil and fuel and get carb cleaner spray in to cylinder wait five mins and empty out. Refill crank case with oil and clean spark plug. Fill gas tank note it might smoke for about 10 to 15 mins as it burns off remaining oil.
    Nov 02, 2014 | Food Mixers
    How much oil does my H 600 Mixer hold ( Hobart in the Transmission
    1 gallon of 90w Gear Oil -- can be purchased from AUTOZONE! Make sure when you have completely drained from the large drain screw from under the mixer toward the back of where the attachments go on but not part of the part that spins around known as the Beater shaft! Once you have drained out all of the oil -- from the top where the front screw attaches the head or cap of the mixer -- add the oil there and make sure you are watching the sight glass to see when it is at the HALF way mark in other words when the oil level (TIP: Use a bright led flashlight to shine directly at this sight glass to view level) reaches to the midway mark of the oval sight glass, THEN STOP! It is full! Carefully start mixer on 1st gear and then 2nd so on and so forth to make sure everything is getting relubricated correctly and slowly -- don't just go setting it on 3rd or 4th speeds as you want to baby the mixer when you just put in new gear oil
    Hope that helps!
    Jun 12, 2014 | Hobart H600 Stand Mixer
    How do you change or add oil to a Hobart H600 mixer
    there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
    Jan 02, 2010 | Hobart H600 Stand Mixer
    PLEASE HOW TO CHANGE OIL OF A HOBART MIXER H-600 C Cooper Lebanon PA
    underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
    Dec 31, 2009 | Hobart Food Mixers
    Howdy, We have a Hobart H600 mixer and it looks like it needs oil. Where do I add the oil and what type should be used? Wesley McMenamins Pubs & Breweries
    take off top cover, where the front screw on top cover threaded into is the fill plug for the trans.drain oil replace drain plug , also ck. sight glass if dark or cloudy replace,@this time.trans. oil can be bought @ any hobartoffice the part# for the trans. oil is102973-66 that will come in a 128 oz bottle you will not need all of it. pour a little @ a time till oil hits line on sight glass. please vote thanks
    Oct 16, 2009 | Hobart H600 Stand Mixer
    Dishwasher will not drain at the end of cycle
    Can you hear the drain pump humming or running?
    If so, undo your drain hose from the drain or under your sink (if applicable) and look inside the spiggot (or small pipe) where you removed the drain hose from.
    It may be blocked?
    Repost if you need anymore help.
    Thanks,
    Adrian.
    Jun 18, 2009 | Bosch MUM4420UC Compact Series Stand Mixer
    Thunderbird ARM-01 Planetary Mixer Logo
    174 people viewed this question
    Top Thunderbird Food Mixers Experts
    Marvin
    Marvin
    ADMIN Canada
    ADMIN Canada
    ray gallant
    Are you a Thunderbird Food Mixer Expert? Answer questions, earn points and help others
