Question about Nikon Coolpix 5000 Digital Camera
Image lcd upside down - Nikon Coolpix 5000 Digital Camera
1 Related Answer
mookid
  • 148 Answers
SOURCE: Nikon D50 LCD
It sounds to me that there is moisture in the camera. Send it to a repair centre.
Posted on Dec 11, 2008
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
Our LCD is ceiling suspended, upside down. When I was resetting the time for cleaning, I think I touched a button on the remote that turned the image on our screen upside down. I can't figure out how to...
1. Press the KEYSTONE button on the remote control. 2. Go down to Manual with the \/ or /\ button, then press > to select it. 3. Select V:INVERT, or H&V:INVERT, to flip the image.
Mar 04, 2011 | Hitachi CP-X260 LCD Projector
Ceining Mounting
in the menu (settings) change the image orientation.
May 10, 2010 | InFocus IN5102 LCD Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
The image is flipped upside down and won't go back I think the camera might have been dropped
THIS IS A REPAIR SHOP TASK
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. iF IT IS PERMANENTLY UPSIDE DOWN yhen most probably the switch has worn out.and its not resetting.
You could try a few gentle taps to see if it releases the micro switch
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | JVC Everio GZ-MG130 Camcorder
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Inverted image
no solution I know and I have the same problem!!! Did you find a solution yet???
Mar 04, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Images on LCD are upside down.
You have to go to settings and adjust from there...find LCD settings and that should do it.
Jun 10, 2008 | JVC GR-D770 Camcorder
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Nikon Coolpix 5000 Digital Camera Logo
15 people viewed this question
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
