Dell V515w Multifunction Printer Logo
p
pamela Posted on Jun 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my scanned photo printing out in red? - Dell V515w Multifunction Printer
Gary Smith
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 106 Answers
  • Posted on Jun 12, 2014
Gary Smith
Expert
Level 2:
Cheetah:
Answers
106
Questions
Helped
24944
Points
243
The other colors are out of ink.
Peter Dragonetti
Level 3:
  • Master 798 Answers
Peter Dragonetti
Master
Level 3:
Answers
798
Questions
Helped
209184
Points
2183
Hi pamela, proberly you are missing one or more ink to the printer, it could be the margenta and maybe black. Normally you can check it on the software installed on the computer it should notice you wich color that are missing when you connect the printer to the computer. Another possibility is that the ink is dryed and therefore not working on the printer, for that there should be a cleaning software on the computer, you find it under Programs and Dell......"something", hope it helps, if not then return here.....pls rate my answer....
1helpful
2answers
What dos BK and CL lights mean?
BK is the black print head and CL is the color print print head.
2answers
Printing an enlarged version of a scanned photo
The best way is to use software like Corel PhotoPaint and RESAMPLE the pix to the sze you want. YOu typically will get better resolution.
You could also try selecting the "Fit To Page" setting of the printer window before you tell it to print.
Seems to do everything but scan to computer it will scan and print a photo but when I try to scan to computer it prompts, "place document on planten glass" well the document is on the planted glass but it...
Click Start, choose printers and faxes, choose scanners and cameras, right click WIA Canon MP970, click properties, choose events tab, choose select an event, scroll to "attach to email".
2answers
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Well I don't know how to scan a photo and file it or take it to print
s.gif Follow these tips to ensure your scanned photo turns out to be a stunning print.
Resolution:
  • You'll want a higher dpi when scanning an image that you want to print.
  • If you want to scan an image and reprint it at the same size, 300 dpi works best.
File format:
  • TIFFs are ideal for printing enlargements, but a JPEG will suffice if you are printing a 4" x 6" photo.
Quick tip:
If you are printing a 4" x 6" image as a JPEG, but think that you may someday want to make a bigger print, archive a larger TIFF file of your photo. Unlike JPEGs, TIFFs can be edited and resaved without compromising the image quality.
1helpful
2answers
I cannot scan photographs to computer
hi! there,
well,if you are trying to print a photo under photo album
and you want to select photo or you are to fetch photo, if you click this you are going to menu of your windows exactly, on that you go to my picture,on that menu select your picture to print,if you selected your picture your going back to your photo print menu in this photo print menu it will flash your picture to print,there option there before you print,set all this e.i your photo size 4x6,5x10 or wallet size depend on you,on lay out you have to select how does it print on you photo paper is it 4 pic on one photo paper or 6 etc..the thing is it has you to return in menu in order to flash your photo,this will help you print your own photo no need to go to your photo shop to develop it easy.cheers have a good day thank's to log in fixya don't forget to rate me.
2answers
Photos too red
Reset your printer to factory settings and try again
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
