Question about LaCie Computers & Internet
How to update 40gb u2&i2? - LaCie Computers & Internet
Posted by Jim Meaders on
  • 4 more comments
  • Peter Dragonetti Jun 12, 2014
    Hi Jim Meaders, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? do you want to replace the harddsik ??
  • Jim Meaders
    Jim Meaders Jun 12, 2014
    I have an old 40gb Lacie external harddrive, but have lost the power cord. I have the old USB connector, but it does not show up on my current iMac or on my old Classic iMac. On the bottom it has 40GB U2&I2.
    If it is external maybe it need a power supply or a replacement of the original one, hope it helps....
    is it 2,5`` or 3,5`` harddisk
    is it 2,5" or 3,5" It is sounding like you do not use the right power supply pls look here : here is one possible power supply, pls. check the specifications :https://www.lacie.com/us/products/produc...
  • Ray Cooke Jun 19, 2014
    from what I read here you need that lost power 'cord' which will be the power source to make it work.
    If you want to get the right item go here:http://support.digidave.co.uk/index.php?...
    Fill in the form with EVERY BIT of information you have and they will be able to serve you with the correct PSupply. They have the item you need in stock. They need the full name and part number of your Lacie drive. If not on the outer case you will find it on the inside of the case.
    Good Luck
    Ray
How do I correct error U2-40 on Sharp AR-M236
U2-40 is the error code for the toner cartridge.
It indicates a fault with the chip in the cartridge.
Try entering simulation mode to reset the error first, to do this make sure the machine is in COPY mode.
Then press the following 4 keys in order: #*C*
then enter 16 & press the copy start key.
Then follow the instructions on the screen to reset U2 error.
When complete, press CA key to exit simulation mode.
If the error re-occurs then the toner cartridge will have to be replaced & the machine reset again as above.
Hope this helps.
Dave.
Jan 16, 2017 | Sharp Office Equipment & Supplies
Can a model A1059 ipod be charged via usb?
yes, but you need to have itunes on the computer you are charging it from.
Feb 18, 2013 | Apple Ipod Gen 4 A1059 U2 4th Gen 20GB and...
Excel Tool VBA Password Recovery
Are you looking to unlock a protected sheet or actually recover the password? I can help you with the former.
Note this will only work to unlock a worksheet. It will not recover the VBA editor password (however this is possible by very hard to explain.)
1) Open the excel sheet you want to unlock,
2) Open VBA editor, (Alt+F11 while in excel)
3) add a module (insert > module)
4) and paste in this code into the main window (big window on the right)
Sub PasswordBreaker()
Dim i As Integer, j As Integer, k As Integer
Dim l As Integer, m As Integer, n As Integer
Dim i1 As Integer, i2 As Integer, i3 As Integer
Dim i4 As Integer, i5 As Integer, i6 As Integer
On Error Resume Next
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If ActiveSheet.ProtectContents = False Then
MsgBox "One usable password is " & Chr(i) & Chr(j) & _
Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
ActiveWorkbook.Sheets(1).Select
Range("a1").FormulaR1C1 = Chr(i) & Chr(j) & _
Exit Sub
End If
Next: Next: Next: Next: Next: Next
End Sub
5) Then either:
5a) go back to the excel window, click Developer > Macros > select PasswordBreaker
6) Or just hit the play icon (green triangle) in the top of the VBA editor
This will unlock the sheet, and give you a password which will unlock it in the future.
Note: Due to the encryption method used in excel, there are many possible passwords which will unlock the sheet. This will give you "a" password which will work but it will not be the one that you originally set up. Both the original and this one will still work.
Jan 20, 2013 | Excel-Tool Excel Tool VBA Password...
Windows 7 driver for buslink CS-160-U2
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps
Jan 03, 2013 | BUSlink CipherShield CS-160-U2...
I dont have a CD driver for my microtek eyestar camera. can i have a link who can help me install my camera?
This has the same chipset as a Microtek Eyestar U2s and works on Windows Xp.
(XP DETECTS THE CAMERA - EXTRACT THIS FILE TO A FOLDER THEN USE CONTROL PANEL'S DEVICE MANAGER TO 'UPDATE DRIVER' AND POINT IT AT THAT FOLDER.)
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | Microtek Eyestar U2s Webcam
Pano po mag cheat ano tina type
pano poh i2 gagana bka poh ma game hack detected ph i2 @ ma hack ang account ko
Apr 06, 2011 | Crossfire XP1000D Car Amp
IF I HAVE A MOTOR WITH STAR DELTA WINDING AND NO LABELING IS DONE HOW WILL I CONNECT THE CABLES TO THE MOTOR
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
Mar 09, 2011 | Kitchen Ranges
Which is the latest ypu2 firmware?
Support site for sub type yp-u2:
http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=YP-S3&dType=D&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-S3
Scroll down and select the exact model: A page with
manual> software> firmware> will show up.
At last check for the description of the latest firmware upgrade.
Sep 05, 2009 | Samsung YP-U2 MP3 Player
PS3 40GB stopped reading discs after 15 months!
I think this might be hardrive failure, if so, you need to send it to sony to get it fixed
Aug 09, 2009 | Sony Playstation 3 (PS3) Console
Samsung yp u2/xb
i have the samsung yp-u2 b 512mb mp3 player but now no power and i do't about it frimware ver
chip ver is 3500
plz send me frimware/solution of it my id is
[email protected]
Sep 13, 2008 | Samsung YP-U2X Digital Media Player
Computers & Internet Logo
87 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
