Question about Sharp AL 1631 Copier
Reset sharp ar 203 - Sharp AL 1631 Copier
5 Related Answers
Adorjani Laszlo
  • 1316 Answers
SOURCE: SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Posted on Sep 01, 2009
Anonymous
  • 32 Answers
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Posted on Apr 17, 2010
Anonymous
  • 3 Answers
SOURCE: IS there a reset code for a Sharp AR-507 copier,
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
Posted on May 18, 2010
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Posted on Jan 14, 2013
intelsrinu
intelsrinu
SOURCE: sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Posted on Apr 18, 2013
Total counter reset program for sharp ar 5618
Can not be done. people then would reset the counters on old machines and sell them as new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 16, 2015 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 maintenance reset
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-203E copier, scanner, printer
You can download driver software for your sharp AR-203 from here http://sharp-ar-203e-series-mfp-driver.software.informer.com/download/ Hope this helps,
Please rate if this solution was helpful, thanks!
Jul 19, 2011 | Computers & Internet
Sep 01, 2009 | Sharp AL 1631 Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
