Question about LG Studioworks 563N 15" CRT Monitor
LG Studioworks 452V 15" CRT Monitor
Screen on and off and tik sound
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: Peculiar Problem in LG studioworks 563N monitor?
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
Posted on Mar 28, 2007
Anonymous
SOURCE: LG Studioworks 700S 17" CRT
hey the back cover will not open if you do not open the foot stand of the monitor and put it on the table facing the screen down then loose the screw and open the cabinet its simple.
Posted on Jul 17, 2007
Anonymous
SOURCE: LG Studioworks 552V 15
It is standy by problom.Find the problom instandy by section
Posted on Aug 12, 2008
Anonymous
  • 65 Answers
SOURCE: LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Posted on Oct 06, 2008
Anonymous
  • 62 Answers
SOURCE: LG Studioworks 452V LED's blinking
1. L O T Problem.
2. power supply out put problem
3. Drypoints at neck base.
Posted on Oct 21, 2008
1. L O T Problem.
Oct 21, 2008 | LG Studioworks 45 14" CRT Monitor
Aug 04, 2008 | LG Studioworks 552V 15" CRT Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Mar 28, 2007 | LG Studioworks 563N 15" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
48 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
