Question about Symphonic ST419E TV
Symphonic tv menu help - Symphonic ST419E TV
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf .
I hope this helps.
Mar 01, 2015 | Symphonic SC3813 13 in. TV/VCR Combo
I'm trying to play my Xbox on a Symphonic Tv model
push the av/tv button in the tv panel.
May 03, 2013 | Televison & Video
How to switch symphonic tv to cable
What is the exact model number to your Symphonic?
Jun 10, 2012 | Symphonic Televison & Video
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
How do i turn my symphonic tv to input mode or game mode without a remote
press menu on the tv, press the volume up button, and select on
Dec 19, 2010 | Symphonic ST419E TV
Tv picture is getting too big for the screen. Can the picture size be reduced?
Hi, well this is most likely a Aspect Ratio issue, this can be set via the TV's Menu. You simply need to adjust this aspect ratio, to suit you viewing requirements.
It is all explained how to do this in your user manual, link provided below. http://www.devicemanuals.com/guide/Television/Symphonic/Symphonic-ST420FF-20-TV-Owner's-Manual-T0RVek16az.html
Sep 29, 2010 | Symphonic ST420FF 20" TV
I cant select games mode manually on the symphonic
I think, after you have the rca jacks inserted into the tv and to the game you're playing, youshould be able to move the channel button down past channels 3 and 2. And or hit menu on the tv and look for setup. Try that!
Nov 29, 2009 | Symphonic ST419E TV
I have a Symphonic WF2703 TV with no remote. How can you access the external inputs without remote
you will have to access the menu-if you do not have a menu button-you can purchace a universal remote-try symphonic or funai codes
Sep 07, 2009 | Televison & Video
I do not have a remote control for my Symphonic tv and I am trying to put the tv on channel 3 or 4 but I can't. It goes from channel 2 to 8. Please help.
Below are some places where you can purchase a symphonic remote control. But if you don't fancy buying one why not tune channel 8 and upwards to the station's that your are after and just forget about the 3,4,5,6,7. My quess is that the tv system is set to skip these channels. If you go to Menu > tv settings, check out the channels that you are skipping, it should be in the installation part of the tv setting's menu. Make sure that where it say's SKIP > OFF on all of the missing channel's.
Hope this is of some help. Bit long winded but hey! :-)
Hughie.
www.remotecontrolscenter.com/symphonic/ -
www.tootoomart.com/buy-symphonic+remote+control/ -
Jun 17, 2009 | Televison & Video
On the symphonic tv how can I get it to swith the input mode. I am trying to set up WII
Menu go to video change inputs to which outlet you are using for External jacks For Example If you hook jacks to AV1 on back then change input in menu to AV1.
Dec 28, 2008 | Symphonic ST419E TV
Symphonic ST419E TV Logo
Top Symphonic Televison & Video Experts
Steven Wander
Steven Wander
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
