Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080) Logo
A
Anonymous Posted on Jun 11, 2014
How doi wire a sat nav docking station - Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080)
1 Related Answer
Anonymous
  • Posted on Nov 05, 2009
SOURCE: my sat nav says i have no sat recption
Then sucks for you
1helpful
2010 Nissan Altima s 4 cylinder my factory radio holiday is a scan never stops on a station
scanning for what?, not told ,AM, FM or SAT?
SCAN FAILING IS ANTENNA BAD.
(AT BEST) IT FELL OFF. THE WIRED CONNECTION MARKED ANTENNA
yes it does or FM radio will be dead. for sure!
some cars the connection is to windshield antenna
and then later windshield glass was replaced wrong
wrong glass or not plugged back in.
reading your service manual now
base radio only
SAT rec. is pin 37 roof antenna
FM rec is pin 75 ant.
with NAV or with out NAV
i will do NAV no. BOSE system factory
pin 81 window antenna AM/FM
pin 107 with NAV am/fm
as you cans see there are 4 options new
for RADIO head end and NAV choices.
we can not guess what is there.
now what you are scanning for.
How to install USB3.0 eSATA 2.5"/3.5" horizonatal mobile HDD Docking station?
Hi
Once you have the drive installed in the docking station you will need to install the drivers on the host PC, if your drive is not showing up in my computer, then either the drive is faulty, the docking station is faulty or the drivers have not installed correctly.
1 listen to the drive can you hear clicking noises from the drive, or is there any activity at all from the drive if not then the drive is either not sat in the holder correctly so is not getting power. or if it seated ok then the drive has gone faulty.
2. If the Docking Station is faulty return it and get it replaced
3 Remove and reinstall the drivers.
Cliff
MCP
While my FM setting works perfectly, I can't pick up any stations in MW or LW. Any Advice?
Check with an Audi Dealer. There are some stations that went Digital along with the TV stations. Your receiver may be outdated.
My partner has many addressess entered on his sat nav that he says he has no idea how they got there. can a sat nav mis enter street addressess incorrectly?
The answer is No...... someone may have input an area while just playimg around with it, or just located a gas station, shopping ...etc while traveling.
They can be removed by going to Tools.... Settings ... MyData
Can u play cds with sat nav on
Only if its a hardware based sat-nav, if its a head unit sat nav with a sat nav disc in then no.
Does the sat nav work without the disc in the head unit... if not then no.
Tomtom one sat nav 18 months old is now taking upto 5 minutes to get a gps signal. When desination is entered the calculation is done tap done and continue then it says gps signal was lost and takes...
try downloading tom tom home to your computer and use your dock or cable to connect it to your computer, switch on your tomtom and allow it to connect to your computer and updates should automatically happen, this should fix it, good luck
G1 pairing problem
tomtom is coming out with software soon to be able to use your g1 as a gps device. theres apps on the market that let you view traffic updates just look up gps on the apps market and find one there. i believe google maps does traffic updates. you should get the docking station for your car it replaces expensive gps devices.
Aug 18, 2009 • HTC G1
1helpful
2answers
Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
3helpful
Can you put factory sat nav in an X5 when it does not already have it in
Hello There
Yes it is possible to install the factory sat nav in you X5, but apart from the head unit you will also need:
  1. new wiring loom
  2. dvd navigation unit installed at the back
  3. TMC radio unit again at the back
  4. bluetooth unit
All the interior needs to come out i.e seats, floor carpets, door trims.
If you feel brave enough then there are BMW forums which gives you very detailed information on how to to it, but don't expect to get it done in a day or even two, a week is probably realistic time. It took me 2 weeks to do my first 3 series.
Hope this helps. Please don't forget to rate me.
Many Thanks
Jul 12, 2008 • 2005 BMW X5
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
