CAN NOT TURN PHONE ON WAS USING IT FINE AND THEN IT JUST TURNED OFF COMPLETLY BATTERY IS CHARGED
SOURCE: D900 - Wont turn on !
CHANGE THE CHARGE CONTROL IC,LOCATED BY THE BTEMP BATERY SAME LIKE D500
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
SOURCE: Phone won't hold charge at all
it's because of water damage, there should be a little square && it should be WHITE, most likely if your having this problem its because the little square is RED.
buy a new phone.
SOURCE: My Samsung SGH-t819 Phone turned itself off, won't come back on.
your battery in your phone is worn out.
go to your local cell phone shop and buy a new one..
charge it up and your set
SOURCE: Phone won't turn on
When you power up first let it going into off chargeing mode, then hold the power button to turn it on, continue to hold it through this whole process, then after the sitck together box has been completed (which may take a few attempets) rapidly push the right soft key until your phone jump in and out of the t-zones area which should be your default right soft key buttong then you should be able to use your phobe normally, note that it did take me a good half an hour of doing this to make my phone through the whole process. :)
