Adobe Photoshop CS5 Upsell from Photoshop Elements  Windows (65048229) Logo
A
Anonymous Posted on Jun 11, 2014
Using font from another application
Importing fonts from another application to cs5
Matt Wallach
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 30 Answers
  • Posted on Sep 23, 2014
 Matt Wallach
Contributor
Level 1:
New Friend:
Cheetah:
Answers
30
Questions
0
Helped
620
Points
30
Fonts from applications are installed in your font folder in windows and should be available to other applications installed.
3 Related Answers
A
Anonymous
  • Posted on May 06, 2008
SOURCE: Legacy text
fdjgjfjgj
Dave117
Dave117
  • 134 Answers
  • Posted on Jun 24, 2008
SOURCE: Copy/paste concern: fonts getting changed
I think this sounds similar to a problem my friend had once.. & it was caused by the font missing or not recognised by Windows. I could be way off base here, but anyway, we found a CD with thousands of fonts on it & installed the missing font. After that, it appeared correctly. If you go to control panel (WinXP) and go to the FONT folder, is the font in there? If not, I beleive you might have to add it. If you still have problems, pls post them here. Pls also provide the operating system version and also identify the actual font thats missing.. That is, what does InDesign see the font type as? Rgds,
Anonymous
  • 75 Answers
  • Posted on Nov 13, 2009
SOURCE: My fonts change when I open the file o another
You can install the font on the computer on which you intend to open it, include the font on a disk with the file, or save the file as a PDF document. Good luck with it.
User fonts not appearing in Photoshop CS5
too many fonts , there may be corrupt the font cache,, remove unwanted fonts and check if there are incompatible fonts files
2answers
What is causing an HP LaserJet 8150 Error 82.0180?
It's from your jet direct card. Turn off the by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">printer andarrow-10x10.png pull out the network card. Turn the printer on and verify it goes to ready. Turn off and reseat the card and see if the printer comes to ready.
If yes - upgrade the jetdirect firmware and by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">the printerarrow-10x10.png firmware
If no, try the other EIO by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">slotarrow-10x10.png.
If that still doesn't work, try a cold reset with the card installed (hold down the green button as you power on, in 5-10 seconds the display will flash cold reset and you can let go and see if the printer comes to ready) Good luck! :)
2helpful
2answers
HI GUDPM JUST WANNA ASK HOW TO DOWNLOAD FONTS IN NOKIA N7O????
Changing N70 Fonts f you are one of those who do not like the plain default font or if you are a "dare to be different" kind of person then this one is for you! Change the fonts to whatever you have available or whatever suits your taste. Get ready for a little facelift for your phonemag-glass_10x10.gif smile.gif
Some background information: Nokia N70 does not use TTF font files, instead it uses GDR file which is a compilation of all the fonts that will be used by the phone. What we will do in the following steps is select the fonts that we want to use, use an application to compile the GDR file containing those fonts and finally uploading the font to the handset. Alright, time to begin.
#1. Download and install GDR crreator Download it here. http://www.crazylittleworld.com/n70/egdrsetup.zip
#2. Run the application. Dont worry about the funny language. I will explain how to use it to make working fonts.
#3. You will see various tabs in the application. Each tab is there to set the font for a certain part of the phone. The phone preview on the left shows the part where the font belongs. Navigate till you get familiar with what is under each tab.
#4. Under each tab, click browse to select the font, set the size (defaults should work fine unless your font is too small or too big) and select whether you want just the basic character set (ASCII/Unicode) or want all the characters + symbols from that font (Symbian/Unicode). From my experience Symbian/Unicode is only needed for Text Messaging (2nd tab in the application). See the image below for descriptions on application.
Easy GDR
#5. After you've set the font, click the "Compile Font" button (see image below) to add the font to the GDR and have a look at "Preview Font" window to get an idea of what the font will look like on the phone.
Easy%20GDR
#6. Finally, click the "Compile to GDR" button and save the file. Name it as you please.
Easy%20GDR
#7. Now transfer the GDR file to your N70 via Bluetooth. Create a folder named "Fonts" in C:\System and copy the file from inbox to the Fonts folder (like we did with the Screensaver files above). In the end you should get this - C:\System\Fonts\<filename>.gdr
#8. Delete the GDR file from Messaging -> Inbox and restart the phone.
2answers
How to import fonts to photoshop?
  1. Regardless of the source, download the font and save it in a fonts folder on your hard drive.
  2. Step 2 Double-click the fonts folder and choose "File." You should be able to select "Install New Font" at this point.
  3. Step 3 Find the fonts you want to install. They may be on a CD or in a folder on your hard drive. When you download fonts from an online site, save them in a place that is easy to access when you install them in Windows.
  4. Step 4 Highlight the TrueType or OpenType font you wish to install and click "Ok." This will complete the installation. Programs, such as Photoshop will automatically incorporate the new font in the list provided by the program.
  5. Step 5 Go to the start menu and select "Settings." Open your control panel. In Windows XP, the control panel will be in the start menu. There is no need to look for "Settings" first.
Hope this is what you need
Mel
How to set it 20 characters per inch
Where do you want to set the font?
Do you want the font as the default font on the printer or do you want the application to call the font?
Application wise, to get a 20 cpi character font, you need to place the font change into the document.
Remember, even if you set the default font as a 20 cpi, if the application calls for a 10 cpi font like Courier, the printer will change the default font to the 10 cpi font for the life of the current print job unless there are additional font calls within the print job.
The software (Application always overcomes default settings)
Don
MY HEWLETT PACKARD DESKJET 3520 PRINTS IN SUCH SMALL FONTS ITS VERY HARD TO READ.HOW DO I CHANGE THE FONT SIZE TO A NORMAL BOOK SIZE FONT?
Change the font in the application that you are using.
The problem may be that the printer's resident fonts does not include the font you are calling. So the printer's logic says, "Go find the best font you can." The font search gives you the wrong font.
If your printer allows you to print out the fonts, do that and make sure the font you want is in the list.
If it is not, then you will have to use a "Soft font" and make sure that your application knows to download/include soft fonts to the printer
Don
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
