Philips 190B6CB/27 19" LCD Logo
A
Anonymous Posted on Jun 11, 2014
How to unlockOSD controls - Philips 190B6CB/27 19" LCD
2004 buick rendezvous cruise control problems
Which engine ?
Cruise Control Description and Operation (3.6L)
Cruise Control Description and Operation (3.4L)
Do you know what all is involved in C.C. operation ?
Cruise control is a speed control system that maintains a desired vehicle speed under normal driving conditions at speeds above 40km/h (25 mph). However, steep grades may cause variations in the selected speeds. The main components of the cruise control system are:
• The cruise control module assembly
• The cruise control switches
• The cruise control release switch
• The powertrain control module (PCM)
• The stoplamp switch assembly
• The vehicle speed sensor
The cruise control module controls the operation of the cruise control system. The cruise control module monitors the signal circuits of the cruise control switches. When the normally open cruise On/Off switch closes with a switch activation, the cruise control modules detects a high voltage on the signal circuit. The cruise control module activates the cruise control system.The set/coast switch and the resume/accel switch will not operate the system when the cruise control module has not activated the system based on the cruise control on/off switch signal circuit .
The cruise control module monitors the cruise control set/coast switch in order to determine when to capture and maintain the vehicle speed. The cruise control module monitors the vehicle speed signal circuit in order to determine the desired speed. The PCM pulses the vehicle speed signal circuit at 4000 pulses per minute. After an initial set speed has been established, the cruise control module also uses the cruise control set/coast switch signal circuit in order to tap down the set speed when the cruise control module detects a switch activation.
The cruise control module monitors the cruise control resume/accel switch signal circuit in order to determine when to resume the previous set speed. This feature only works within the same ignition cycle and as long as the cruise wasn't turned off using the cruise control On/Off switch since the last cruise engagement. After the set speed has been resumed, the cruise control module also uses the cruise control resume/accel switch signal circuit in order to tap up the set speed when the cruise control module detects a switch activation.
The cruise control module assembly has a controller and an electric stepper motor to vary the throttle in each different cruise control mode. Two components in the module assembly help to do this. The electronic controller and the electric stepper motor. The controller monitors vehicle speed and operates the stepper motor. The stepper motor operates in response to the controller, to maintain the desired cruise speed. The electric stepper motor moves a strap that is attached to the cruise control cable which moves the throttle
tip
Radio Shack Remote Control Remote Codes 150-2000 thru 630-5311
RadioShack Itza-2 Universal Remote Control (Purple) <a href="http://support.radioshack.com/support_video/60765.htm">150-2000</a> <br /> RCA RCU410 Remote Control <a href="http://support.radioshack.com/support_video/66870.htm">150-2101</a> <br /> RadioShack 4-in-One Light-Up Remote <a href="http://support.radioshack.com/support_video/64489.htm">150-2102</a> <br /> RadioShack 5-In-One Learning Light-Up Remote <a href="http://support.radioshack.com/support_video/64491.htm">150-2103</a> <br /> RadioShack 6-in-1 Home Theater Remote Control <a href="http://support.radioshack.com/support_video/64493.htm">150-2104</a> <br /> RCA RCU600RS 6-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/66945.htm">150-2105</a> <br /> RadioShack 8 In 1 Touch Screen Remote Control <a href="http://support.radioshack.com/support_video/65894.htm">150-2107</a> <br /> RCA RCU300 Remote Control <a href="http://support.radioshack.com/support_video/67858.htm">150-2109</a> <br /> RCA RCU500 Universal Remote Control <a href="http://support.radioshack.com/support_video/67860.htm">150-2111</a> <br /> RadioShack 3-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/69065.htm">150-2113</a> <br /> RadioShack 4-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/69067.htm">150-2114</a> <br /> RadioShack 4-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/70735.htm">150-2114A</a> <br /> RadioShack 5-In-1 Remote Control <a href="http://support.radioshack.com/support_video/69108.htm">150-2115</a> <br /> RadioShack 8 In 1 Remote Control <a href="http://support.radioshack.com/support_video/69110.htm">150-2116</a> <br /> RadioShack 8-In-1 RF Learning Remote Control <a href="http://support.radioshack.com/support_video/69112.htm">150-2117</a> <br /> RadioShack 4-In-1 Remote Control <a href="http://support.radioshack.com/support_video/72447.htm">150-2118</a> <br /> Philips Magnavox SpongeBob SquarePants 3-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/72638.htm">150-2122</a> <br /> RadioShack 3-In-1 Football Remote <a href="http://support.radioshack.com/support_video/68789.htm">150-2125</a> <br /> RadioShack 4-In-1 Flag Remote Control <a href="http://support.radioshack.com/support_video/69864.htm">150-2126</a> <br /> RadioShack 3-in1 Golf Bag Remote <a href="http://support.radioshack.com/support_video/69204.htm">150-2127</a> <br /> Universal Big-Button Remote For Special Needs <a href="http://support.radioshack.com/support_video/69934.htm">150-2129</a> <br /> Guide Remote Programmable 4-In-1 Remote Control <a href="http://support.radioshack.com/support_video/72688.htm">150-2130</a> <br /> RCA 4-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/73238.htm">150-2131</a> <br /> RCA RCU600BL 6-In-1 Remote Control <a href="http://support.radioshack.com/support_video/73922.htm">150-2132</a> <br /> RadioShack 6-In-1 Touchscreen Remote Powered by Kameleon <a href="http://support.radioshack.com/support_video/69319.htm">150-2133</a> <br /> RadioShack 5-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/70587.htm">150-2135</a> <br /> RadioShack 4-In-1 Remote Powered by Kameleon w/Light-Up Keys <a href="http://support.radioshack.com/support_video/72091.htm">150-2136</a> <br /> RadioShack 8-In1 Touchscreen Remote Powered by Kameleon <a href="http://support.radioshack.com/support_video/73014.htm">150-2138</a> <br /> Sony RM-V202 4-In-1 Remote Control <a href="http://support.radioshack.com/support_video/73919.htm">150-2139</a> <br /> RadioShack 4-In-1 Family Favorites Universal Remote <a href="http://support.radioshack.com/support_video/72875.htm">150-2142</a> <br /> RCA RCU450 4-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/72939.htm">150-2145</a> <br /> RadioShack Remote Control Keychain <a href="http://support.radioshack.com/support_video/68965.htm">630-1166</a> <br /> Universal Electronics Remote Control Watch <a href="http://support.radioshack.com/support_video/69954.htm">630-5311</a>
on Jun 11, 2011 • Televison & Video
tip
Radio Shack Remote Control Code Instructions 150-1901A thru 150-1999
Realistic Universal Remote Control <a href="http://support.radioshack.com/support_video/26219.htm">150-1901A</a> <br /> RadioShack 8-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/26221.htm">150-1903</a> <br /> Realistic Four-in-One Remote Control <a href="http://support.radioshack.com/support_video/26223.htm">150-1904</a> <br /> RadioShack 4-in-1 Remote Control <a href="http://support.radioshack.com/support_video/9536.htm">150-1904B</a> <br /> RadioShack 6-in-1 Remote Control <a href="http://support.radioshack.com/support_video/6663.htm">150-1905</a> <br /> RadioShack 3-in-1 Remote Control <a href="http://support.radioshack.com/support_video/9537.htm">150-1906</a> <br /> RadioShack Easy VCR Programmer Remote Control <a href="http://support.radioshack.com/support_video/7973.htm">150-1907</a> <br /> RadioShack 5-in-1 Remote Control <a href="http://support.radioshack.com/support_video/6570.htm">150-1908</a> <br /> RadioShack 4-in-1 Remote Control <a href="http://support.radioshack.com/support_video/6725.htm">150-1909</a> <br /> RadioShack 3-in-1 Remote Control <a href="http://support.radioshack.com/support_video/9538.htm">150-1910</a> <br /> RadioShack Light-Up Remote Control <a href="http://support.radioshack.com/support_video/9539.htm">150-1911</a> <br /> RadioShack Itza Remote Control <a href="http://support.radioshack.com/support_video/9540.htm">150-1912</a> <br /> RadioShack Itza Remote Control <a href="http://support.radioshack.com/support_video/35323.htm">150-1913</a> <br /> RadioShack Itza Remote Control <a href="http://support.radioshack.com/support_video/35315.htm">150-1914</a> <br /> RadioShack Pocket Remote Control <a href="http://support.radioshack.com/support_video/16680.htm">150-1915</a> <br /> RadioShack Pocket Remote Control <a href="http://support.radioshack.com/support_video/47657.htm">150-1915B</a> <br /> RadioShack 3-in-1 Easy Remote Control <a href="http://support.radioshack.com/support_video/16726.htm">150-1916</a> <br /> RadioShack 3-in-1 Easy Remote Control <a href="http://support.radioshack.com/support_video/44686.htm">150-1916B</a> <br /> RadioShack Phone Up 4 Remote Control <a href="http://support.radioshack.com/support_video/34875.htm">150-1917</a> <br /> RadioShack 6-in-1 A/V Remote <a href="http://support.radioshack.com/support_video/36485.htm">150-1918</a> <br /> RadioShack 6-in-1 RF Remote Control System <a href="http://support.radioshack.com/support_video/18620.htm">150-1919</a> <br /> RadioShack Universal Remote Control <a href="http://support.radioshack.com/support_video/15740.htm">150-1921</a> <br /> RadioShack 6-in-1 Remote Control <a href="http://support.radioshack.com/support_video/42245.htm">150-1923</a> <br /> RadioShack 7-in-1 Remote Control with Lighted Keypad <a href="http://support.radioshack.com/support_video/42247.htm">150-1924</a> <br /> RadioShack 6-in-1 IR/RF Remote Control <a href="http://support.radioshack.com/support_video/45116.htm">150-1925</a> <br /> RadioShack 3-in-1 Simple Pocket Universal Remote Control <a href="http://support.radioshack.com/support_video/50835.htm">150-1926</a> <br /> RadioShack 3-in-One Pocket Remote Control <a href="http://support.radioshack.com/support_video/48421.htm">150-1930</a> <br /> RadioShack 3-in-One Easy Remote Control <a href="http://support.radioshack.com/support_video/48700.htm">150-1931</a> <br /> RadioShack 6-In-1 Remote Control <a href="http://support.radioshack.com/support_video/51276.htm">150-1934</a> <br /> RadioShack 7-in-1 Home Theater Remote Control <a href="http://support.radioshack.com/support_video/51278.htm">150-1935</a> <br /> RadioShack One For All - The Finder Remote Control <a href="http://support.radioshack.com/support_video/34166.htm">150-1940</a> <br /> RadioShack Wireless Infrared Remote Control Extender <a href="http://support.radioshack.com/support_video/7039.htm">150-1959</a> <br /> RadioShack 2-in-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/61532.htm">150-1989</a> <br /> RadioShack 3-In-One Pocket Remote <a href="http://support.radioshack.com/support_video/52292.htm">150-1990</a> <br /> RadioShack 4-In-One Remote Control <a href="http://support.radioshack.com/support_video/52294.htm">150-1991</a> <br /> RadioShack 4-in-One Light-Up Remote Control <a href="http://support.radioshack.com/support_video/52296.htm">150-1992</a> <br /> RadioShack 4-in-One Smart Light-Up Remote Control <a href="http://support.radioshack.com/support_video/52298.htm">150-1993</a> <br /> RadioShack 6-In-1 Smart Audio/Video Remote Control <a href="http://support.radioshack.com/support_video/52962.htm">150-1994</a> <br /> RadioShack 7-in-One IR/RF Remote Control <a href="http://support.radioshack.com/support_video/52964.htm">150-1995</a> <br /> RadioShack VCR Programmer Remote <a href="http://support.radioshack.com/support_video/61534.htm">150-1996</a> <br /> RadioShack Itza-2 Universal Remote Control (Clear) <a href="http://support.radioshack.com/support_video/56310.htm">150-1998</a> <br /> RadioShack Itza-2 Universal Remote Control (Purple) <a href="http://support.radioshack.com/support_video/56312.htm">150-1999</a>
Where is the cruise control fuse located?
In the SJB - smart junction box , Under the dash ! There are three fuse's - F2.27 10amp - F2.32 10amp - F2.17 15amp . Is your air bag light lit ?
SECTION 310-03: Speed Control 2004 Taurus/Sable Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 07/02/2003 Speed Control The vehicle speed control system consists of the following components:
  • Brake pedal position (BPP) switch
  • Speed control actuator cable
  • Speed control switches
  • Speed control deactivator switch
  • Speed control indicator
  • Smart junction box (SJB)
NOTE: The clock spring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the speed control actuator are:
  • Vehicle speed signal
  • Deactivator switch
The outputs of the speed control actuator are:
  • Speed control indicator lamp
  • Speed control actuator cable controlling the throttle position
2helpful
2answers
What is an ICP - RCC - Speedometer fuse for on a 1997 ford taurus dohc ICP - RCC?
Hey Brian ,
ICP - Integrated control panel
RCC - Remote Climate Control Module
Integrated Control Panel-Electronic Automatic Temperature Control
Control Assembly The Taurus, Sable vehicles group together the following systems into a single integrated control panel:
  • AM/FM stereo radio
  • clock
  • rear window defroster switch
  • electronic automatic temperature control (EATC)
  • full-logic cassette tape player
  • compact disc player control (optional)
The remote climate control module is mounted to the A/C evaporator housing behind the integrated control panel. The integrated control panel is connected to the remote climate control module with a dedicated two-wire communication link. The integrated control panel EATC features:
  • a vacuum fluorescent display (VFD) for displaying set temperature, ambient temperature, function and diagnostic trouble codes (DTCs).
  • electro-luminescent backlighting for all buttons and graphics.
  • function override buttons.
  • temperature control and blower speed rocker switches.
1helpful
Fuse Box Diagrams (Inside and Engine) for 2009 Volkswagen Tigua?
Attached are the diagrams requested - good luck!
Fascia 1
Fuse, (Amps), Circuit
F1 -
F2 -
F3 -
F4 -
F5 -
F6 -
F7 -
F8 -
F9 (5A) Supplementary restraint system (SRS) control module
F10 (10A) Four wheel drive control module
F11 (5A) Parking aid control module, self-parking system control module
F12 (10A) Gas discharge headlamp control module (LH)
F13 (5A)
ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
module, transmission control module (TCM), reversing lamps, engine management system
F14 (10A)
ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
control module, trailer control module, AC control module, instrumentation control module, CAN data bus
gateway control module
F15 (10A)
Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
direction control module
F16 (10A) Gas discharge headlamp control module (RH)
F17 (5A) Instrument panel
F18 (10A) Mobile telephone control module, multimedia control module
F19 (10A) Steering column function control module 2
F20 (5A) ABS control module, AC system, transmission control module (TCM)
F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
F22 (5A) Alarm system, multifunction control module 2
F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
F24 (10A) Door function control module, driver, door function control module, passenger
F25 (20A) Transmission control module (TCM)
F26 -
F27 -
F28 (40A) AC control module, auxiliary heater
F29 (15A) Rear screen wiper motor
F30 -
F31 (20A) Auxiliary power sockets, cigarette lighter
F32 -
F33 -
F34 -
F35 -
F36 -
F37 -
F38 (10A) Steering column function control module 1
F39 (20A) Headlamp washers
F40 (15A) Trailer control module
F41 (15A) Trailer control module
F42 (20A) Trailer control module
F43 (25A) Sunroof control module
F44 (25A) Parking brake control module
F45 (25A) Heater blower motor, heated rear window
F46 (30A) Door function control module, driver, door function control module, passenger
F47 (30A) Door function control module, driver, door function control module, right rear
F48 (15A) Fuel pump (FP)
F49 (20A) multifunction control module 2
F50 (25A) Parking brake control module
F51 (40A) AC/heater blower motor control module
F52 (30A) Seat heater control module
F53
(20A/30A)
Headlamp washers
F54 (30A) Auxiliary power sockets
F55 (15A) Lumbar support adjustment
F56 (15A) Suspension control module
F57 (25A) Sun blind control module
F58 (1A) Trailer warning lamp
F59 (20A) Multimedia control module
F60 -
Fascia 3
in engine bay
Fuse (Amps) Circuit
F1 -
F2 -
F3 (5A) Multifunction control module 2
F4 (30A) ABS/ESP system
F5 -
F6 (5A) Instrumentation control module, steering column function control module 2
F7 (40A) Ignition main circuits
F8 (25A) In-car entertainment (ICE)
F8 (25A) Voltage converter
F9 (5A) Mobile telephone control module
F10 (5A/10A) Engine control module (ECM)
F11 (20A) Auxiliary heater control module
F12 (5A) CAN data bus gateway control module
F13 (15A/30A) Engine control module (ECM)
F14 (5A) Engine management system
F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
F16 (30A) Multifunction control module 2
F17 (15A) Alarm system horn
F18 (30A) Audio system
F19 (30A) Windscreen wiper motor
F20 (10A) Engine management system
F21 (10A/20A) Engine management system, fuel pump (FP) control module
F22 (5A) Clutch pedal position (CPP) switch
F23 (10A) Engine management system
F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
F25 (40A) ABS/ESP system
F26 (30A) Multifunction control module 2
F27 -
F28 (50A) Glow plug control module
F29 (50A) Electric seats
F30 (50A) Ignition switch circuits
Location Component
1 Petrol: Engine control (EC) relay 1
1 Diesel: Ignition main circuits relay
2 Petrol: Engine control (EC) relay 2
2 Diesel: Engine control (EC) relay
Code p1443
without knowing your make or model:
  • p1443
    Evaporative Emission Control System Control Valve
  • audi
    EGR Valve Position Sensor Signal Too Low
  • bmw
    Leakage Diagnostic Pump Control Circuit Signal High
  • ford
    EVAP Control System Purge Control Solenoid or Purge Control Valve Fault
  • hyundi
    EVAP System Tank Cap Missing
  • infinity
  • lexus
    Secondary Air Injection Vacuum Switching Valve Circuit Malfunction Bank 2
  • mazda
    Evaporative Emission Control System Large leak detected
  • mitsubishi
    EVAP Purge Control Valve 2 Circuit Malfunction
  • nissan
  • suburu
    Evaporative Emission Control System Vent Control Function Problem
  • suzuki
    EVAP Purge Control Valve Malfunction- Stuck Open
  • toyota
  • volkswagon
  • 2helpful
    Direct tv remote to visio tv
    I can help you with your Vizio TV & DirecTV remote control.
    This is a list of all the Vizio TV control codes for DIrecTV remote controls:
    11758, 10864, 10885, 11499, & 11756.
    Complete instructions on entering DirecTV remote control codes are here.
    I hope that helps.
    _________________________________________
    DirecTV Remote Control Code List Download
    DirecTV Remote Control Manual Download
    DirecTV Remote Control Code Entry
    DirecTV Remote Control Code Search
    DirecTV Remote Control Onscreen Setup
    1helpful
    What is code F-24
    E11 Fill time too long. Refer to test (1).
    E13 Water leak in tub or air leak in air bell. Refer to test (2).
    E21 Water not pumping out fast enough. Refer to test (3).
    E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
    defective. pump.
    E24 Drain pump relay on control board failed. Replace console control board.
    E31 Pressure sensor not communicating with control board. Refer to test (4).
    E35 Pressure sensor indicates water overfill. Refer to test (5).
    E36 Console control board problem. Replace console control board.
    E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
    E41 Control board thinks the door switch is open. Refer to test (6).
    E43 Console control board thinks the door locking device has failed. Refer to test (7).
    E44 Console control board problem. Replace console control board.
    E45 Console control board problem. Replace console control board.
    E46 Console control board problem. Replace console control board.
    E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
    E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
    E52 Bad signal from tacho generator. Refer to test (8).
    E56 High motor current. Refer to test (9).
    E57 High current on inverter. Refer to test (9).
    E58 High current on motor phase. Refer to test (9).
    E59 No tacho signal for 3 seconds. Refer to test (10).
    E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
    E5B High temperature on heat sink. Replace speed control board.
    E5C High temperature on heat sink. Replace speed control board.
    E5D Communication problem. Refer to test (11).
    E5E Communication problem. Refer to test (11).
    E5F Communication problem. Refer to test (11).
    E66 Heating element relay failure. Refer to test (14).
    E67 Input voltage on microprocessor incorrect. Refer to test (15).
    E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
    E71 Wash NTC failure. Refer to test (15).
    E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
    E75 Water temperature sensor circuit. Refer to test (12).
    E82 Console control board problem. Replace console control board.
    E83 Console control board problem. Replace console control board.
    E91 Comunnication error between UI board and console control board. Refer to test (16).
    E93 Console control board problem. Replace console control board.
    E94 Console control board problem. Replace console control board.
    E95 Communication error. Replace console control board.
    E97 Console control board problem. Replace console control board.
    E98 Console control board problem. Replace console control board.
    EB1 Incoming power frequency out of limits. Refer to test (13).
    EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
    replace the console control board.
    EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
    EBE Console control board problem. Replace console control board.
    EBF Console control board problem. Replace console control board.
    EF1 Clogged drain pump. Unclog the drain pump.
    EF2 Too much soap. Advise customer to reduce the amount
    of soap they are using.
    1helpful
    Jenn-Air JDS9860AAP Control Panel Problem
    Control Panel
    1. Remove power from unit.
    2. Remove burner switch control knobs.
    3. Open oven door and remove screws securing control
    panel.
    4. Remove screws located on the right and left sides of
    the control panel.
    5. Grasp control panel on the far left and right sides and
    gently pull the control panel out and down.
    NOTE: Gently pull control panel out and down.
    6. Remove infinite switch control knobs, infinite
    switches, indicator lights, rocker switches, and
    electronic control/clock (as necessary) and transfer to
    the new control panel.
    7. Reverse procedure to reinstall control panel.
    Electronic Control
    1. Remove control panel, see “Control Panel”
    procedure, steps 1 through 5.
    2. Remove screws securing electronic control bracket to
    control panel.
    3. Label and disconnect terminal wiring from electronic
    control.
    4. Reverse procedure to reinstall electronic control.try that
    Jan 16, 2008 • Ovens
    Top Philips Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    ZJ Limited
    ZJ Limited
    Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
