Question about Life Fitness F1 Smart Treadmill
Speed stall error f1 smart - Life Fitness F1 Smart Treadmill
I've got a dc7800 Small Form Factor system. After less than a second, a blue window"smart card authentication" and below that, "smart card reader not present".
"System Options Not Set" normally means that the battery that maintains those options has gone dead. That's usually a 2025 coin cell on the motherboard.
I would replace that first thing, then set the BIOS options. Usually, there's another message that comes up, "Press F1 to continue, F10 for setup". F1 will let you system boot, most likely, but doesn't set the options. F10 (or whatever it says) will get you to where you can set the options.
Nov 09, 2015 | Computers & Internet
Display F3 on carrier Ac what problem
Well without a model number, I can tell you this. On some models, F3 indicates fan speed 3, which is high speed.If you push the mode button, these units will switch between f1, f2, f3 and smart fan. No problem.
On others, F3 indicates a fan speed error, either something is keeping the fan from turning, or there is a bad or loose connection somewhere.
On still other models, F3 indicates a freon leak or problem in the refrigerant circuit.
If carrier made their own units, they would probably act the same, but they don't. Model number is important, since the unit could be a daikin, LG or Samsung under the skin...
Nov 29, 2014 | Carrier Heating & Cooling
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 12, 2013 | Life Fitness F1 Smart Treadmill
SMART FAILURE PREDICTED ON HARD DISK 2 TOSHIBA MK2035GSS (S1) PRESS F1 TO CONTINUE. ON START UP COMPUTER GOES TO THIS SCREEN EVERY OPTION ON START UP OF F1 DOES NOT START WINDOWS AND COMPUTER RETURNS TO...
As I understand it, SMART is correct 50-60% of the time...means it's wrong 40-50% of the time.But..You can't take the risk, you have to assume something is wrong with your hard drive. So, i f you have important data there, go to a repair shop and they can save data from your hard drive and replace it, if necessary. If you want to solve it on our own, you need a boot cd with error checking. Any live boot cd with linux does that. Also, there are several live boot cds like Hiren's Boot, with rescue options.
May 11, 2011 | Computers & Internet
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 09, 2011 | HP Computers & Internet
Acer Aspire 5100: SMART Failure on Hard Disk 4
Hello there,
As per experience, SMART Utility will check your HDD for any errors that may occur.
I backed up everything and replaced a new HDD and got rid of the error.
Opened up the problematic HDD and noticed a very light scratch on its "platters".
As for me. Never ignore this warning before something might happen to your HDD and lost important data.
Mar 08, 2010 | Acer Aspire 5100 Notebook
Have a Kenmore Sensor Smart Three Speed Automatic Washer. Getting an F1 code and the machine stops. Why?
The F1 code means the ERC or the touchpad is bad. When you remove the sensor, the ERC thinks the sensor is bad and so gives an F3 code. You can check your oven sensor just to make sure. This page explains:
http://fixitnow.com/2003/02/appliance-tip-of-day-oven-temperature.htm
More information on this problem here.
Mar 05, 2010 | Washing Machines
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
Life Fitness F1 Smart Treadmill Logo
165 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
