Question about Texas Instruments TI-86 Calculator
I am unable to graph a simple equation (y=-1.5x+3) on my TI-86 without getting error 07 message. How do I fix it?
k24674
  • Texas Instru... Master
  • 8,091 Answers
Read on how to set up calculator for graphing. And check your input.
Posted on Sep 02, 2014
5 Related Answers
Patrick
  • 56 Answers
SOURCE: Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
Posted on Nov 12, 2008
Anonymous
  • 11 Answers
SOURCE: How do you set up window range?
or press ZOOM, option 6 (ZStandard).  That instantly resets the window range.
Posted on Jan 28, 2009
Anonymous
SOURCE: I am trying to use
Press 2nd, then 0 (this will take you to the Catalog)
Scroll down until you see "Axes On"
Hit Enter twice
TADA!!!
Posted on Feb 11, 2009
Anonymous
SOURCE: MATH Graph Style Icons
go to apps menu, go to transform app. click uninstall and go to y= screnn and should be a slash on the left and you should be able to graph more than one equation.
Posted on Mar 18, 2009
Anonymous
  • 10 Answers
SOURCE: Ti-89 gives error of "Undefined Variable"
You have to reset
• Press [2nd] [6] (MEM) [F1] [ENTER(RAM)]
• Select 1:ALL RAM
• Press [ENTER]
• Press [ENTER]
NOTE- erased half of my programs(I think only the ones in the main directory)
Posted on Sep 05, 2009
How do I graph a simple equation on my TI-86, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Jun 11, 2014 | Texas Instruments TI-86 Calculator
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
y= (-) 1.5*x +3
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
y= (-) 1.5*x +3
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Everytime I try to graph an equation my calculator says "error 14 undefined" i don't know how to fix it
Error 14 undefined may occur if you are referencing a variable that currently is not defined
Sep 12, 2011 | Texas Instruments TI-86 Calculator
My graphing calculator won't graph anything. I've entered many equations into y=. I even tried to type in a simple linear equation to see if it would even do that. Nothing happened. The window...
You do not say if you get any error message.
Try to reset the calculator Press [2nd][+] to open memory management.
Press [7][RESET] followed by [1:All RAM] [2:Reset]
Then open the Y= editor and to the right of Y1= type in [X,T,theta,n] and press [ENTER]. You will see the straight line y=x.
Please report back what you get.
Aug 02, 2011 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Ti-86 Error Message--HELP!!
To restore memory on a TI 84 to factory settings follow the directions on pages 108 and 109 of the instructions manual (TI 84 Plus Silver). Otherwise look in the index for RESET MEMORY to get the right page. Be sure you read the precaustions!!!!!!
Dec 12, 2009 | Texas Instruments TI-86 Calculator
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to [email protected].
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Getting the Error 13 Dimension
This just happened to me too after i tried to plot some statistics. Press 2nd, +(STAT), then F3 for plot and see that you have all the STAT PLOTS turned off.
Sep 10, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
96 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
