1. Press PLAY from your remote control 2. Press the following button sequence: 1590 2379 390 3. Press PLAY again
This will release the region verification in your player(region free). However, some DVDs (multi region in particular) will not play, since they require region detection from the player unit.
if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution.
Mike @ Compurepair.
DVD region number (playable region number)
This DVD head unit will play back any disc
whose region number is 2 (or All). DVDs
with a region number other than those listed
below, cannot be played on this DVD player.
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray. Press SETUP button on the remote control, which will bring up the menu.
The screen will show: "Region Code: 2" Press [1-6] to manually set the region OR [0] for multi-region.
Press [SETUP] to exit
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
HI,
it depends on whether the drive is multi-region ?
Some drives are region Set, i.e Region 1 ( NTSC-USA )
Region 2 ( UK PAL )
Most Players Are Region Set, To the country they are purchased in, you can sometimes set the player to become, multi-region, via various buttons on the remote or by the front panel.
I offer a service to unlock 99% of DVD Players, to play all or many regions.
We do have a charge for this Service.
Many Thanks mike @ Compurepair.
How to activate the multi-region functionality
1. Make sure the disc tray is open and remove any discs from the player.
2. Key in ‘7 7 7 7’ using the remote control.
3. Select region 0 for a region-free setting.
