Question about Whirlpool Pearl Navarre 7242 True Bathtub with Back Massage - 103558-100
Pearl whirlpool tub won't turn off - Whirlpool Pearl Navarre 7242 True Bathtub with Back Massage - 103558-100
Pearl Trillium diverter and hand held shower
The faucets on your Pearl tub do not come from Pearl. They were supplied by the local plumber who installed the tub.
Go to your local plumbing store and match up what you have.
Rod
US Parts Center
Jan 04, 2014 | Maax Pearl By TRILLIUMbla Pearl Trillium...
Tub goeson then turns off
This sounds like a bad motor. It sounds as if it is overheating.
You will need the model number and brand of pump in order to find the correct replacement.
rod
us parts center
888-521-6183
Apr 04, 2013 | Maax Pearl By CS42wh Pearl CS42 in White
I need to know how to re program my tub , it seems to be stuck in the pause mode
Disconnect the power for a min or two and then turn it back on this should reset everything back to default. Then go through the setup instruction as if you were starting new. If that dosen't do it the control unit is faulty.
Jan 30, 2011 | Whirlpool Pearl Navarre 7242 True Bathtub...
I need new trim parts to change from gold to nickle on a pearl jetted tub model 143391-1 trim rings handle light cover..ect.
go to http://www.uspartscenter.com/shopbybathmfg.aspx you should be able to find the parts for your tub there.
Dec 16, 2010 | Whirlpool Pearl Navarre 7242 True Bathtub...
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
My pearl whirlpool bathtub has turned on mysteriously when no one is home and no water in the tub...only one years old! Is this a sensor problem? Motor problem? touch-pad control problem? Please help, I...
Sorry, didn't realize I would need to pay money for the answer. I will deal with Pearl bath on my own. Thanks for the help, please remove my email from your mailing list.
Nov 02, 2009 | Whirlpool Pearl Ballade True Bathtub with...
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Parts for my pearl corner tub
any plumbing suply house would have it. good luck
Feb 18, 2009 | Whirlpool Pearl Navarre 7242 True Bathtub...
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Whirlpool Pearl Navarre 7242 True  Bathtub with Back Massage - 103558-100 Logo
55 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
