SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
SOURCE: Need a new check valve for a Keurig B70 coffee maker
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
SOURCE: Keurig Platinum B70 Coffee Maker stops working and
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
SOURCE: How do I descale a
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101
