Question about Lexar Electronics - Others
Lexar Echo MX not being recognized
Tried in different usb ports, different computers, app;e computer. The red led flashes as it starts to be recognized and then disappears(intermittent)
Anonymous
Try this: Go to Start, right click on My Computer, select manage. In the left pane click device manager, scroll to Universal Serial Bus Controllers. Delete all of them. System may not allow some to delete, thats fine just delete all that it will allow. Then leave your usb connected to the PC and reboot. OS will reinstall all usb drivers on its own, and it may then see your stick.
Posted on Aug 17, 2014
2 Related Answers
ynotphone
ynotphone
  • 192 Answers
SOURCE: When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY
Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
Posted on May 19, 2009
Anonymous
  • 90 Answers
SOURCE: All of a sudden no computer will recognize the
These drives do die from time to time. If a comp wont see the drive....it's dameged ...sorry. :(
Posted on Feb 19, 2010
How do i get my computer to recognize my usb flash drive
If your device drivers are up to date, the USB ports are totally recognized. If the USB device plugged into the port is not initialized, it may not be recognized by the computer operating system. If a USB flash drive was working and no longer works; it could have been damaged when removed from the computer when last used. Flash drives are sensitive to Static Charge. Like when you rub the feet on a carpet and a spark of electricity jumps from a finger to another person. You must use the Eject method when removing Flash Drives.
Feb 10, 2018 | Computers & Internet
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
Feb 19, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
Usb device installed but does not show up in my
First, try it in a different USB port on your computer.
Connect it to a different computer.
If it is still _not_ recognized, then it is "dead".
If it is recognized, then it's your computer that has the problem.
Jan 24, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
Computer does not recognize coby mp705
remove the device, swear a few times, promise your son you'll buy him a proper ipod, then give it to the dog to play with.
Dec 25, 2008 | Coby MP-C7085 MP3 Player
USB port does not recognize 1Mb flash drive
try connecting the card directly to your computer usb port. unplug other usb devices. if that fails, try the card in a different computer.
May 17, 2008 | ASUS P5P800-VM Motherboard
Computer wont recognize usb drive
try to use another connector! and try connecting it to other USB ports!
Dec 06, 2007 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Electronics - Others Logo
83 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
John Waters
John Waters
Damon Nesselrodt
Damon Nesselrodt
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
