Question about Coleman Camping, Backpacking & Hiking
PML8000 Spotlight how do i replace the battery
Posted by Kenny Lashley on
Stephen Potts
  • 447 Answers
Screw off the bulb housing.
Posted on Jun 12, 2014
BATTERIES FOR MODEL JXSL10
Just take battery out and match it with the same type-12 volt sealed lead acid battery-I think mine cost 30$ online. I haven't had luck finding a replacement bulb. That is what my spotlight needs!
Dec 03, 2013 | Jeep Heavy Duty Jxsl10 Rechargeable...
Searching for vector 2 million rechargeable spotlight battery
Checdk with Mr. Battery or other battery dealers - check Yahoo for battery sales - this probably uses a sealed battery. I think you will find the cost of replacing the battery is more than the cost of buying a new light.
Nov 20, 2012 | Vector 1 Million Rechargeable Spotlight
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
Dec 13, 2009 | Cars & Trucks
Cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
Oct 23, 2009 | Camping, Backpacking & Hiking
Will not hold a charge...Looking for a replacement battery? Any Ideas?
http://cgi.ebay.com/VECTOR-1-MILLION-CANDLE-POWER-SPOTLIGHT-FLUORESCENT-NEW_W0QQitemZ220469526499QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335501ffe3&_trksid=p3286.c0.m14
Aug 31, 2009 | Vector 1 Million Rechargeable Spotlight
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
191 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
efs_perpends
efs_perpends
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
