Question about Sony KV-32S26 32" TV
Why doesnt my sony wega plasma tv turn on. model #kde50xs955
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Posted on Jan 01, 2009
    Anonymous
    • 318 Answers
    SOURCE: sony tv will not turn on
    the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
    powersupply rectifier diodes, power trasistor lekage,
    diodes, zener diodes,
    if a 90-110 volts to the line trasistor,
    a line transistor be checked.
    the tv simple problem
    Posted on Apr 01, 2009
    Anonymous
    SOURCE: sony wega tv wont turn on
    sony kv-36hs500 no enciende y parpadea el stand by
    Posted on May 01, 2009
    Anonymous
    • 129 Answers
    SOURCE: Sony Wega tv
    Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
    Posted on Jul 26, 2010
    gopakumarg43
    • 76573 Answers
    SOURCE: my tv sony wega dont
    Hello
    Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
    If it happens even after this process, you just do the following
    Press the following button on your remote control as stated
    "Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
    You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
    Just report the result to me through Fixya. Ok.
    Posted on Nov 05, 2010
    Sony KDE50xs955 Ser#2001641 Plasma green light blinks but TV won't come on. I try on and off and it finally comes on what do you think has to be replaced.
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
    Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
    Jan 06, 2015 | Sony Televison & Video
    I need a replacementnbase stand for a sony wega 42" plasma tv
    Contact Sony with the model number to see if available or not, other than that Google the model number with base to see what comes up, last resort might be to look on EBAY.
    Dec 10, 2012 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
    Sony 50" plasma no picture model pdm 5010
    Did you get this issue fixed? If not and you are giving up on this TV, I would like to buy the original Table stand that came with this TV from you if you still have them. I currently mounted this TV but looking to move it to another bedroom but I lost the original TV stand. Please email me at [email protected].
    Feb 18, 2010 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
    Xbr950 sony lcd tv has two verticals lines on left side.any solution.
    i dont have a solution but i had the same problem, i'm up to six lines on mine, and now it only turns on sometimes. it doesnt look like we will get a solution any time soon
    Feb 14, 2010 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
    42 sony wega plama veritcal line
    The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
    Beware,the flatcables wich the resistors are located on are verry fragile!
    Nov 02, 2009 | Sony WEGA KZ-42TS1 42 in. Plasma...
    Plasma problems
    It's in standby mode.
    Let's do a reset and see what happens
    While holding down the reset button on the remote
    Press the power button on the tv
    (The tv will turn itself off the back on)
    Now release the reset button
    Let me know how this works
    Jan 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
    Power turns off right away
    Its correct, Sony is no more selling plasma and I think many companies has already shut plasma production and CRT TV as well.
    All TV manufacturers are busy in LCD TVs.
    Jan 17, 2009 | Sony WEGA KE-50XS910 50 in. HDTV-Ready...
    My tv dose not turn on
    replace the flyback
    available from for a great price from
    www.electronix.com
    May 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    SONY TV Model KV-36FV300 Problems
    plz contect me we repair lcd plasma and projection tvs
    Yogesh-9811440932
    Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
    Apple TV and Sony KE32TS2 Plasma TV
    That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
    Nov 18, 2007 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
    Sony KV-32S26 32" TV Logo
    Top Sony Televison & Video Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Nasir Muhammad
    Nasir Muhammad
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
