Emerson EWF2703 27" TV Logo
Question about Emerson EWF2703 27" TV
How to set my emerson ewf2703 back to factory settings
2 Related Answers
Anonymous
  • 346 Answers
SOURCE: TV Screen Vertical
you need a qualified tv technician to solve this problem. the vertical ic has to be changed
Posted on Nov 16, 2008
gopakumarg43
  • 76851 Answers
SOURCE: emerson mdl#ewf2703, do not have the remote, need to swith mode to video
As there is no "Menu" button to this set at its front panel, you must have its remote control to select inputs.
Posted on May 20, 2012
Emerson mdl#ewf2703, do not have the remote, need to swith mode to video
What numbers does the tv need to be at so that you are able to have a clear picture
this all depends on what you decide looks better to you. there is no preset number or level to be able to set .This is a crt set so the picture should be good anyway
Emerson EWF2703 27" No remote will work on tv. Is it expensive to repair, I feel it must be within the tv and the receiving end of the infrared sensor. Any idea of the cost to repair it. Or any other ideas...
Could be your infared sensor has gone bad.or it might just need to be reset back to factory reset. If it was unplugged for a while before this problem arrose then then the reset is probably your solution. Hope this helps.
HOW DO I GET CLOSED CAPTION OFF MY TV
try to go on the menu of your tv set. i think you can find it there.
1helpful
Remote won't work - channel stuck at Video2
Remove the battery from the remote then press each button twice.
Insert new batteries then check the operation of the Remote control.
To troubleshoot the video 2 issue, connect different video source to the TV then select the connected video input.
If the issue persists then try resetting the TV to the original factory settings.
good luck!!!!!!!!!!!!
Connecting hdmi and dvd player to 32" emerson
get a splitter switch if you can find one .it will allow 2 devices ,and you can select which one you want.
TV Screen Vertical
1helpful
How to change the input
First, the bad news: Unfortunately, you are correct - the only button to change inputs is on the remote, which you no longer have.
Now, the good news: You can buy a universal remote, set it for your TV model, and have control of your inputs again. The first link below is for the URC R6, which is available at any Walmart for about 20 bucks. You can set it up for an Emerson TV, no problem. Here's the link for it:
http://www.universalremote.com/consumer/products.php
Also, here is a link for the owners manual to your Emerson EWF2703, in case yours has gone missing with the remote:
http://www.emersonaudiovideo.com/pdf/om/EWF2703.pdf
Not a perfect solution, but it will work, and it will work just as fast as you can get to your local Walmart or equivalent.
Cheers
Broken remote cant set to component
On most TV's you can select the source or input by going into the menu on the tv. It is usually under set up although all tv's vary. I hope this assists you and thanks for using Fix Ya. If you need further assistance please let me know.
Top Emerson Televison & Video Experts
Jaime Hernandez
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
