Try http://www.etrailer.com/faq-wiring.aspx. Very informative site with tons of detailed wiring drawings. Good luck.
SOURCE: Wiring diagram
If you are going from a 4 pin on your trailer to the 7 pin on the truck. You need to go to parts store or a department store (ex Wal Mart) and look in trailer section and find the adapter. Thats what I did. Also Remember if your lights don't work on trailer, check the plug to make sure its tight or check the fuse under your drivers side rear seat for that fuse box.
SOURCE: Need engine harness wiring diagram for 2001 chevy truck V8
The Best diagram you can get is at alldatadiy.com it has the sections and locations and color of wires with pictures.
SOURCE: wiring diagram for a chevy truck
you can give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local GM-dealership in the parts department and they be able to print you off the pictures and diagrams you will need wish you the best of luck Michigan Man.
SOURCE: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Hi Robert Danner, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
What wiring diagram are you in need of? the pigtail on the truck, or how to wire the trailer portion of the hitch harness? I can help with either.
