Question about Texas Instruments TI-86 Calculator
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
This should be a simple slope graph, but my calc.(TI-86) won't graph it.
k24674
  • Texas Instru... Master
  • 8,091 Answers
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Posted on Aug 28, 2014
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: error :invalid DIM
This is my first post on this site, but I've had friends at school ask me about this. Apparently I'm like a calculator genius or something...
One solution I know of is clearing the RAM. Sounds strange, doesn't it? But it fixed three different calcs.
Be sure to back up or archive important data before doing this.
Posted on Oct 21, 2008
Patrick
  • 56 Answers
SOURCE: Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
Posted on Nov 12, 2008
Anonymous
SOURCE: Tan Cos and Sin errors
go to:
mode
select DEGREE rather than RADIAN three lines down.
Posted on Jan 21, 2009
Anonymous
SOURCE: MATH Graph Style Icons
go to apps menu, go to transform app. click uninstall and go to y= screnn and should be a slash on the left and you should be able to graph more than one equation.
Posted on Mar 18, 2009
Anonymous
  • 10 Answers
SOURCE: Ti-89 gives error of "Undefined Variable"
You have to reset
• Press [2nd] [6] (MEM) [F1] [ENTER(RAM)]
• Select 1:ALL RAM
• Press [ENTER]
• Press [ENTER]
NOTE- erased half of my programs(I think only the ones in the main directory)
Posted on Sep 05, 2009
How do i find slope and then graph it
Select two points P1 and P2 on the line. Read their coordinates P1(X_1, Y_1), and P2(X_2, Y_2). If the points are given to you that is even better: you will not have to approximate their coordinates.
The slope of the straight line that passes through P1 and P2 is the ratio s=(Y_2-Y_1)/(X_2-X_1).
A slope is a number and cannot be graphed. The line that has the slope can be graphed if you have its complete equation y=slope*x + initial value.
To graph a curve on the TI84 open the Y= editor, type in the second member (right side) of the function say on line Y1= then press the Graph function key.
Feb 05, 2013 | Texas Instruments TI-84 Plus Calculator
How do you grsph a slope?
You do not graph a slope as the slope is just one number that characterises a linear function. Rather you need to draw the linear function.
Press the Y= key to enter the function editor. On line Y1= type in a legitimate function such as y1= 3x-2 and press ENTER. Press the GRAPH key to view the graph.
Sep 24, 2011 | Texas Instruments TI-83 Plus Calculator
How do I clear things left in the stat plot window?
To clean the slate so to speak, just reset the RAM.
  1. Press [2nd][+] to access the (MEM)ory management function
  2. Press [7:Reset]
  3. Press [1:All Ram]
  4. Press [2:Reset]
  5. Press [CLEAR] to erase the "RAM cleared" Message
Calc
Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
What is the cube root function on the ti-86
look under math calc and there should be an x^3 key
Sep 29, 2009 | Texas Instruments TI-86 Calculator
A friend gave me a TI-86 graphing Calc. I wont turn on!!!
maybe try changing the small memory battery inside, I think its a cr1616 or cr1620. If this doesn't work use it as a paperweight.
Apr 23, 2009 | Texas Instruments TI-86 Calculator
IT-86 Both batteries removed, now dead
Use the TIconnect or TIGraphlink software to reinstall the programs. You will find the programs in the TI Program archives.
ftp://ftp.ti.com/pub/graph-ti/calc-apps/86/.
Hope it helps
Jan 18, 2009 | Texas Instruments TI-86 Calculator
How do I graph ordered pairs on a TI 86 plus?
Use the stat menu. Enter 1st member of a pair in List1, Enter 2nd member of pair in List2. Graph the data as a scatter plot in stats plots.
Hope it helps.
Jan 15, 2009 | Texas Instruments TI-86 Calculator
TI-86 Calculator Problem
Most likely you're trying to graph a function while you have the stat plot turned on. Turn off the stat plot and try it again.
Oct 16, 2007 | Texas Instruments TI-86 Calculator
Hi
you should first put it in the form y=mx+b
m-slope
b-y-intercept
x + 2y=4
-x -x 1subtract x from both sides
2y=4-x
/2 /2 2 divide both sides by 2 (to get y alone)
y=2- x/2 now you can put that into your calc. (Y= button)it would like like this on your screen Y1=2-X/2 (X is found under mode)
next hit graph
2nd, TABLE will give you a list of x-values and y-values
hoped i didn't leave anything out and i hope this helped
Sep 27, 2007 | Texas Instruments TI-82 Calculator
Texas Instruments TI-86 Calculator Logo
147 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
