Question about Cell Phones
My t-mobile concord,when i turn off phone it completely shuts down,any ideas. Wmp
Posted by bill on
Sean Wright
    President:
  • 2,030 Answers
UH it is suppose to shut down when turned off....or do you mean when you shut screen off, the whole phone goes off?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Jun 11, 2014
How can i load whatsapp on my t mobile concord? keeps saying insufficient space
You don't have enough memory storage on your phone. You need to delete unused apps you don't need to make enough space for the app.
Dec 02, 2014 | T-Mobile Concord
Why does my phone have an echo?
Some phones will echo if the volume is turned up to high. Try turning the volume down a couple of bars and see if that helps.
May 28, 2014 | T-Mobile Concord
How do i turn off safe mode from a T- Mobile Concord smartphone
Take the battery out for a couple of hours or let it completely die and when you start it back up it should work. If it doesn't solve the problem your firmware may need to be updated. You can do that by going to your settings.
Apr 04, 2013 | T-Mobile Concord
My t- moblie concord phone keeps restarting itself
I just solved this problem on my son's phone. I removed the sim card and sd memory card. Then I had to do a factory reset. Press and hold the volume down and the power button until the picture of the android shows up. Then the menu button. This will open the recovery screen. Use the volume control to move up and down the screen and select the restore by pressing the home key. After I made sure it would turn on and stay on, I replaced sim and sd card.
Mar 28, 2013 | T-Mobile Concord
My Concord shuts down multiple times a day
May have a low memory issue going on.. Turn off any unnecessary features, and try pulling the battery out and putting it back in.. If that doesn't help, you my have to do a hard reset and restore it back to its factory condition... Here are the instructions to reset your phone: To perform a hard reset using hardware keys, follow these steps: Power off the device. Press and hold Volume Down key. Press and hold Power key until the Android and Triangle logo appears on screen. Let go of buttons once the logo appears. Press the device Home key. When the Factory Data Reset option appears, use the Volume keys to scroll to and select it with the Menu key. When Wipe data? appears, use the Volume keys to highlight Yes, and select it with the Menu key. Once Data Wipe Complete appears, use the Volume keys to highlight Reboot System Now and select it with the Menu key. Hope this helps...
Mar 05, 2013 | T-Mobile Concord
THE MOBILE IS TURN OFF AND ON RESPECTIVLY
DId you get the cell phone wet anytime recently?
Dec 06, 2008 | Sony Ericsson K750i Cellular Phone
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Sep 26, 2008 | 1993 Chrysler Concorde
Phone turns on and off.
you will need to reflash the phone so take the phone to a mobile service center to have that done.
Aug 17, 2008 | Samsung SGH-t629 Cellular Phone
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
