Question about i-mate PDA2k Pocket PC
How to fix the too much smoke of the engine 3au
Posted by arnel joaquin on
Jim Pattison
    Master:
  • 1,004 Answers
If there is smoke coming out of your pocket pc, you have higger problems. Take an air hose and blow out the dirt and see where the smoke is coming from.
Posted on Jun 11, 2014
Looking for manual for a 3AU Toyota engine
The best solution you'll get from books at www.reliable-store.com
These are books containing in fo on repair, service, troubleshooting , parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 23, 2018 | Toyota Cars & Trucks
Timing belt guide for toyota 3au engine
go to the given and get the factory service and repair manual to fix your problem
Nov 10, 2017 | Toyota Cars & Trucks
Solution for carburetor gas overflow of toyota 3au engine car
Carb float is stuck or maybe has lost its buoyancy and the fuel flow is not being stopped when carb is full. Hence, the overflow.
Sep 16, 2016 | Toyota Cars & Trucks
Excess smoke
The general rule: white-ish smoke indicates coolant in the exhaust, meaning a blown head gasket, whereas darker smoke indicates motor oil in the exhaust, which means that one (or more) cylinders have a broken ring, and the engine needs a ring job.
Fix for white smoke: replace head gasket.
Fix for black smoke: ring job.
Oct 05, 2011 | 2003 Lexus ES 300
Blue smokes come out tailpipe when i start the car but stops afte
Helllo there
Symptom: Gray or blue smoke from the exhaust. You notice gray smoke coming from the exhaust when you start your car. The smoke may or may not disappear after the car is warmed. If it is, it is less noticeable. The smoke may have a bluish tint to it. Possible causes:
  1. The engine's piston rings may be worn.
    The Fix: Replace piston rings. (Generally not a DIY job)
  2. The engine's valve seals may be worn.
    The Fix: Replace valve seals. (Generally not a DIY job)
  3. Damaged or worn valve guides.
    The Fix: Replace valve guides. (Not a DIY job)
Symptom: Engine uses more oil than normal, and there is some smoke from the exhaust. The oil level is low between oil changes. It appears that the oil is being burned by the engine because of the smoke in the exhaust. You may or may not notice the engine doesn't have the same power as it used to.
Possible causes:
  1. The PCV system is not working properly.
    The Fix: Replace PCV valve.
  2. The engine may have mechanical problems.
    The Fix: Check compression to determine engine condition.
  3. The engine's piston rings may be worn.
  4. The engine's valve seals may be worn.
Jun 01, 2010 | 1989 Buick Electra
00 ford focus wagon a/c & engine smoke problem
Engine smoke problem-- Automatic, chk transmodulator. If oil in vacuum line, modulator is defective. Engine sucking up trans fluid. 10.00 fix . good indicator is smoking at cruising speed or deceleration.
Bad rings smoke under acceleration and bad valve guides smoke on deceleration. poor crankcase ventilation (pcv valve) will cause engine leaks and oil blowing out of dipstick. Good Luck
May 05, 2009 | 2000 Ford Focus
i-mate PDA2k Pocket PC Logo
106 people viewed this question
Top i-mate Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Jax Planet
Jax Planet
Vincent G
Vincent G
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
