Good Afternoon Friend,
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
