Samson Resolv 65a Main / Stereo Speaker Logo
A
Anonymous Posted on Jun 11, 2014
One of the woofers blew out. Where can I get a replacement?
I could not find anything on the internet. I went to a speaker rebuilder and he told me it could not be rebuilt.
They were bought off the back of the truck but great speakers.One of my Vega LS 15 blew a woofer. The 10s are 600W- 2ohms. I hooked them to a H Kardon 3470-100W 8 ohms.Will that damage anything?
In a word, YES! The HK is designed for a minimum 4 ohm load. You can wire (2) 2 ohm speakers IN SERIES to get a 4 ohm load. Do NOT run one of them at 2 ohms as it will overload and damage your amp. Too nice an amp to abuse it like that...
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
1helpful
Please contact by mail describe haw many oHm of subwoofer, active or passive it? may be we can help w/ replacement subwoofer sunrisenohchi@ hotmail.com
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Can i replace the 15" woofer with diecast aluminum
Yes. Contact CV for a replacement. Alternately, if you have a speaker refurbisher in your area, you can have them rebuild the one you have. There are only a few refurbishers/rebuilders in the US, so good luck.
1helpful
4answers
I got logitech speakers X-230 M/N: S-0123A that need ac110-120v- 60 Hz from USA and by mistake plugged it into ac 220 v that is standard in new delhi. there was a spark and smoke from the woofer unit, and...
You have damaged the power supply unit and this would have caused some failures on the power supply and sometimes on the drivers.
So first of all please check the power supply unit, alternatively the DC power required can be supplied by incorporating a new power supply with the same rating but working on 220volt.
repairing the 110 volt supply is no good as you will need again a step down to work , so I suggest this change.
Altec lansing multimedia speaker model ATP3 woffer is giving tearing sound at high base and it seems the woofer is not working at all
Your woofer is bad, probraly blew the megnatic coils, and if mention that it's giving you a tearing sound, then the woofer cone is tear somewhere and is not get the reflex to produce the sound.
My subwoofer atarted making deep humming sound, then stopped working. I changed the fuse and then when i turned it on it blew the fuse. What can i do?
The voice coil of your woofer is off centered and shorting on the armture causing the speaker to draw too much current. The fuse blew thereby protecting the output stages of your amp. Replace the speaker.
4helpful
What is a suitable gale gold woofer replacement?
Really does not matter the point is you can rebuild the woofer for less then replacing with a new one but to each his own on this. But as long as its the same size anything would do for this monitor speaker.
I do not mean to sound generic but its true a woofer is a woofer it is what it is sure there are brands out there but they all work basically the same.
All your doing is buying the name.
Thanks please do click the thumbs above to give me a postive rating for my efforts today,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
