Question about Precor 9.1 Mode 1 Treadmill Repair Parts Eprom
I have a Precor 9.45 I that states error 10 what is wrong with it
Sportsmith LLC
  • Precor Master
  • 918 Answers
Precor Error 10, Line Frequency out of Acceptable Range Probable Cause 1. Treadmill is connected to a non-dedicated AC circuit
2. The AC hot and AC neutral wires are reversed on a 120VAC circuit.
3. The upper PCA has an incorrect jumper setting.
4. Fuse feeding the stepdown transformer is bad.
5. AC line frequency is incorrect.
6. AC line may be excessively noisy. Corrective Action
  1. Treadmill must be connected to a completely dedicated 20amp AC circuit. Both hot and neutral leads must be dedicated to the treadmill. If the circuit is shared with another piece of equipment, it can cause enough electrical noise to make the AC line frequency impossible to identify. The AC circuit for the treadmill must be re-configured as a completely dedicated 20amp circuit.
  2. Many line frequency detection systems observe the AC line frequency on the hot AC line. In the event of a reversed 120VAC circuit, the observation is taking place on the neutral (ground) part of the AC line. Many observing systems are not capable of detecting line frequency on the neutral line. First it must be determined if the reversal is in the AC wiring feeding the treadmill or in the internal wiring of the treadmill. The hot and neutral lines can be confirmed by measuring each in reference to AC (green wire) ground. The hot wire will read full line voltage (commonly 105 - 120VAC) and the neutral should read about 0VAC.
  3. The upper PCA's for some units had a jumper setting for use with SCR or PWM drive circuits. If the jumper was set on the upper PCA as PWM on an SCR unit, the Error 10 appears. Change the jumper setting to SCR to correct the problem.
  4. A pair of fuses were used on some treadmills (C944 PWM version 2 and C96x PWM version 2) that fed the stepdown transformer for the low voltage power supply on the lower PCA. The AC line frequency was observed on the output of one of the fuses. If the fuse blew, AC line frequency could not be detected even though the treadmill appeared normal under other circumstances.
  5. It is unlikely, however, the AC line frequency could be out of acceptable limits. This would more likely occor in countries were AC power systems may not be well developed and controlled. There is little that can be done to correct this issue. If the source frequency cannot be corrected, the only possibility would be replacing the treadmill with one that utilizes a PWM motor controller. PWM motor controllers do not depend on line frequency for speed control.
  6. At times the AC being fed into the distribution system is too electrically noisy to allow correct line frequency identification. This can be caused by other equipment within the AC distribution system creating the electrical noise. It can be difficult to identify the source of the electrical noise. There is little that can be done to correct this issue. The source needs to be located and removed or made electrically quiet. If this cannot be done, the only possibility would be replacing the treadmill with one that utilizes a PWM motor controller. PWM motor controllers do not depend on line frequency for speed control.
Precor Error Code 10 10 Line Frequency out of Acceptable Range
Posted on Aug 06, 2014
The incline on our Precor c964i is stuck in a high position (approx. 10% incline). Other than being on a high incline, the treadmill seems to be working fine.
Hi There,
Precor uses a pair of Triacs to drive the lift up and down. These triacs live on the lower board but are driven by the upper console commands via a serial link between the upper and lower. Most precor lift issues we see are related to the lower board but with Precor it could be an upper board or the CPU Chip that resides on the lower board or a failed Triac. Good Luck
Apr 07, 2017 | Precor Exercise & Fitness
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
Stuck on incline error code 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Feb 16, 2014 | Precor Exercise & Fitness
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
What is error 45 on the EFX 546??
Nov 11, 2012 | Precor EFX 546i Elliptical Version 4
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
The ramp will not go up or down. It's states low battery (546i precor)
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Precor 9.1 Mode 1 Treadmill Repair Parts Eprom Logo
222 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
