Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
Why is our whirlpool gold bottom freezer groaning
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
davidpsr
David Mcintosh
  • 222 Answers
SOURCE: How to i stop my Whirlpool Gold from leaking water
This water is accumulated during the automatic defrost cycle, which occurs every 24-hours. A fan is supposed to pull air over it to evaporate it.
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Posted on Aug 22, 2009
Anonymous
  • 1218 Answers
SOURCE: top half of frig. and freezer not cold .Whirlpool
Good day,
On a side by side machine, that is almost always the fan motor in the freezer compartment not working.
When you open the freezer door, you should be able to hear it run.
If not, you can access the motor by removing the rear panel in the freezer panel and inspect.
If it needs replaced it is a simple nuts and bolts repair.
Posted on Dec 01, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: freezer goes on and then shuts off
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 31, 2010
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Have a Whirlpool Gold fridge. Model #GB2SHDXTQ00. This week the fridge stopped working but the bottom freezer works fine. Is this just a thermostatic control issue? What part might be causing the problem? ...
Check the back wall of the freezer for frost . If there is then it is either the defrost heater, timer or thermostat. If there is no frost check to see if the fan in the freezer is running.
Oct 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a 3 door Whirlpool Gold fridge. The bottom
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Apr 24, 2010 | Refrigerators
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
