Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
Does the Kenmore Elite he 4t front load washer have a flow meter?
Posted by Rod Carr on
Sean Wright
    President:
  • 2,030 Answers
Yes it does
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Jun 11, 2014
What does F-11 error code mean on my Kenmore HE 4t front loader washer?
I believe it means motor control unit failure. Make sure nothing is plugged into same circuit unplug unit for 10 min. and try again . If it still does not work you will need a tech
Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 4t. Controls are locked! Tried unppluging still the "controls locked". ARGHH! What to do???
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Keep in mind, control panel features can differ between models. However, the instructions on how to lock/unlock the control panel are printed on the front panel of these washers and are printed in the owner's manual.
If these prelimiary measures do not work, you may have a more serious problem than a simple operator intervention.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Removing panel cover
Sounds like your drain pump is clogged.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
47 people viewed this question
Michael Thomas
Michael Thomas
Harvey Mahal
Tracy
