SOURCE: False Paper Jam
Hello, My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue. This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue . To isolate the issue, I recommend you to perform below steps. Steps are: -------------- 1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet. 2. Check thoroughly in Printer that there is no small piece of paper in the Printer. 3. Let the Printer be disconnected and idle for 5 minutes. Meanwhile please perform further steps on Computer. Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in your PC Steps are: -------------------- Perform the below steps to restart the print spooler : 1. Click Start>Run 2. Type services.msc 3. Click OK 4. A Window will pop up with so many services listed. 5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart" 6. Restart the Computer. Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue. This should resolve the issue for you. If you need any further assistance on the issue, you can mail me at [email protected] . I'll be glad to help you. Bye.
SOURCE: canon pixma MP620 paper jam
Hello! I have solved your problem! The first thing you need to do is extend the back paper holder all the way up. This should uncover a long rectangular hole. There is a plastic piece with 2 arrows pointing to the right on it (if you are looking at the back straight on). Simply push them to the Right and it will pop up on the Left side. You can now lift that piece out and VOILA there is your misfed paper! Just reinsert the rectangular piece back in after you have taken the misfed paper out! -Gary Maples
SOURCE: paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3,
while printer was turning on,and makings sound as it does normally when
turning on, I pushed through the piece of paper and the rotors stoped
for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
SOURCE: E3 error and no paper is jammed
Hello There please try it may clean it up for you
There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: canon pixma ip1980 service error 6000.. it flashes
you need to open the printer. it has sensors around it. the one that you need to check is in the left side when you are facing the printer. the one that is sensing the graduated circular part. Remove the left cover on the side. then remove the sensor with a philip screw driver and clean it. then place it back and turn your printer on. I hope to be of help to you. Let me know if this works. I did it on mine.
