I hear the grinder turning, but no beans are being ground, even with the bean container filled.
Some models, such as C60 and C65, have a plastic disc about the size of a silver dollar as a guard above the grinder, with very little clearance for the beans to feed below the guard. Oily beans can stick together and hang up on the guard. I noticed when the Fill Beans problem happened, that the grinder didn't sound like there was anything in it, just a whirring sound of the motor.
My field modification to solve this problem was to remove the guard (1 screw), add a 1/4" spacer (made from a 10-24 nut) beneath the guard, giving more clearance. Beans fed great, and the screw was just long enough to re-mount the guard with the spacer below it.
To do this:
1. Unplug the machine.
2. Open the top of the machine. On C60 and C65, there are two OVAL head screws on the back. If you don't have an oval head driver, you can grab them with small vice grips and work them loose. At the top front under the side lids there are two torx screws - much easier to find a driver. Remove the lid, being careful with the wiring to the power switch. The lid can be moved aside with the wiring still connected, just enough to access the guard.
3. Remove enough beans to expose the guard, and remove the torx head screw and guard
4. Put your spacer in place (anything metal or plastic about 1/4" thick with a hole in it will do), and replace the screw, being careful not to over-tighten and strip the threads. You may need to find a similar self-tapping screw 1/4" longer.
5. Replace the top and the 4 screws that secure it. Plug it in and try it.
This turned out to be a bulletproof fix for my machine. I thought about discarding the guard entirely, but seemed like a better idea to leave it in place. You can watch the beans happily feeding into the grinder, and no more Fill Beans light until you actually run out of beans!
Do you find grinds coffee (dry) in the waste cotainer?
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
