Question about Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the year old gas out and put in fresh. What am I missing. Thanks.
Robert Call
    New Friend:
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Posted on Jun 24, 2014
Boiler not running smoothly
needs tune up change filter and nozzle and check electrodes are clean with no build up and clean out chambers
Oct 10, 2016 | Heating & Cooling
Fuel system running rich and stalling
Sounds like it is slightly out of time.
Apr 14, 2014 | Ford Cars & Trucks
My 2002 subaru outback starts just fine but dies within 10 seconds
sounds like a bad fuel pump.
its getting enough fuel to start then its starves after it starts
Dec 23, 2013 | Subaru Outback Cars & Trucks
My 91 Chevy s-10 2 wheel drive p/u w/2.5 four cylinder wont idle and runs rough when i rev the motor which the only way i can keep it running is to feather the throttle. If i unplug the vacuum to the
the problem if from the map sensor.. when you change it it will run rough and keep cutting off,, keep stating it back and reeving over and over as soon as it cuts off again keep repeating until the CPU gets calibrated with the new sensor and it starts idling smoothly..
Dec 30, 2012 | 1991 Chevrolet S-10
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
My 1997 Saturn Has a really hard time starting in the morning, It
check timing and depending on miliage check your ignition system
Mar 02, 2009 | 2000 Saturn SL
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer Logo
600 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
