I need a wiring diagram for condensing unit
SOURCE: Wiring schematic - RUUD
Schematic
All Projects with Photo Preview Browse over 10000 circuits. Now!
www.ElectronicsInfoline.com
SOURCE: Friedrich wiring diagram
COPY PASTE THIS TO YOUR WEB BROWSER TO LOCATE YOUR MANUAL AND DIAGRAM...:)
http://www.airconditionparts.com/filecabinet/PartsLists/TwinTemp_Parts_Service_Manual.pdf
JUST GO TO THE WEBSITE FOR CLEAR DIAGRAM.
SOURCE: Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
