Question about Jensen VM9510 Car DVD Player
Eclipse ucnv884 12v power wire how to conect - Jensen VM9510 Car DVD Player
Where is the ignition control module located
follow the sparkplug wires. where they conect is the ignition module
Mar 12, 2013 | 1997 Mitsubishi Eclipse
How to manually close a 2004 mitsubishi eclipse sunroof
Most manual sunroof closing conection are in the ceiling in or near the back seat area. Usually under a plastic plug or round disk on the ceiling.
Jul 19, 2011 | 2004 Mitsubishi Eclipse
I have 2001 Mitsubishi eclipse and the a/c compressor doesn't engage,tried freon wont take any,and checked relay it's good.
Check your fuse to see if bad. Check conection of electric wire that connects to compressor. Hope this might help.
May 05, 2010 | 2001 Mitsubishi Eclipse
2002 eclipse wont start. electronic immobilizer light flashing. how do i deactivate immobilizer?
disconnect the neg battery terminal for 30 sec leave drivers door open, reconnect and start your car, if the alarm turns on after conecting battery use your key in the drivers door and unlock
Nov 12, 2009 | 2009 Mitsubishi Eclipse Spyder
Loose ground wire on headlight
You may need to pick up a new plug and some **** conecters and replace the plug to the headlight.Remove the old plug from the light ,cut off the wires one at a time and reconnect it to the coresponding wire on the old plug.
Oct 22, 2009 | 1998 Mitsubishi Galant
Put new plug wires on my eclipse now it runs crappy
You may have your plug wires in the wrong order.
The firing order is 1-3-4-2 om cpounter-clockwise rotation. Look at the digram below. Notice the shaded blue is cylinder 1. From there, make sure 3 is the next wire, then 4 and finally 2.
Oct 03, 2009 | 1995 Mitsubishi Eclipse
Lights come on. no power with turning key.
i had the same problem with a side post battery. the bolt was not making good contact with the terminal conected to the wire. i cut the rubber off to remove the bolt and cleaned all the build up. also check for a good ground connection and also the power wire going to the starter it could be a loose connection.
Dec 20, 2008 | 1998 Mitsubishi Eclipse
Eclipse CD8445 Clock Problems
If you lose your preset stations as well, it means that your memory wire (sometimes yellow sometimes red) is not hooked to a constant power source. Get a testlight and find a wire in where the radio is at that has constant power once you find that attach the memory wire.
Nov 17, 2008 | Eclipse 5440
Jensen VM9510 Car DVD Player Logo
73 people viewed this question
Top Jensen Car Audio & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
