Question about Carrier 38CKC060 Air Conditioner
Grill replacement Replace outside grill. I got the new grill through a relative that works for carrier...just need to know if there are instructions on how to get the old one out and the new one in..thanks!
4 Related Answers
Anonymous
  • 143 Answers
SOURCE: Outside fan will NOT turn off
A relay can be welded "closed" and cause this. It is in the outside half of the air conditioner. If you have printed circuit boards, it's a lot harder to guess what's wrong from over here, but I've actually seen this problem when it was caused by a relay. Of course, I am assuming no person has been in there changing wires around.
Open it up, find the relay where one of the fan wires is going, give it a sharp rap with a screw driver handle. If that fixes it, replace the relay.
Posted on Jul 22, 2008
Lou Barta
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
Anonymous
  • 10 Answers
SOURCE: My AC unit is a carrier LCA061P window unit. It
Good possibility. WIth the unit powered off and unplugged check the clearance of the wheel and the collection basin underneath, Debris could be the source but I suspect the bearing is failing on the motor
Posted on Oct 21, 2009
Anonymous
  • 127 Answers
SOURCE: I have a condensor Carrier
The unit is 2.5 ton system. many units can replace the existing, you can upgrade to a 3ton if you wish without problems or upgraded ducting if enough ducting exist.
Brands that will almost fit as is are Payne, Day and Night, Rheem, Ruud.
Posted on Aug 27, 2011
1helpful
HOW TO CLEAN INSIDE OF A GAS GRILL
things you'll need: Turn off gas supply. remove
Gloves grills grates.clean the grill
grill brush grates scrub them with grill
cleaning rags brush. clean anything
putty knife or bristle brush covering the burners. clean
soap clean the burners, lightly
water brush the burner tubes and
make sure all the gas ports are clean and open.Clean the bottom of the grill and lid. Brush or wipe any debris out of the bottom of the grill. If there is peeling black stuff on the grill lid or bottom ,use a bristle brush or putty knife to scrape off. Clean the grease collection tray with soap and water or replace and disposable trays as needed. Wipe down the outside of the grill with soap and water. put the grill back together .. now your ready to grill,
Jun 21, 2020 • Grilling
How do I replace a filter on my 1975 Carrier central A/C?
THE FILTER IS THE AIR FILTER . IN THE RETURN AIR GRILL EITHER IN FLOOR OR IN THE WALL / SOME ARE INSTALLED IN THE UNIT IN THE AIR HANDLER COULD BE INSIDE A CLOSET OR ATTIC OR UNDER FLOOR / FIND AND CHANGE IT . IT WILL BE WHERE THE AIR IS PULLED INTO UNIT ON RETURN SIDE AS I SAID SOME IN FLOOR GRILLS , SOME IN WALL GRILLS . SOME IN CEILING GRILLS . JUST TAKE OUT AND GOTO LOWES OR hd GET SAME SIZE AND REPLACE
I have a new grill for the outside unit..is it difficult to replace? I am fairly handy
Yes, these are very simple to install. I'm not sure about your exact model but generally you just have to remove the top of the unit and the grill slides right up and out. It's only held in by the down pressure of the top being screwed on. Hope thus Helps : )
Battery igniter
If you have an electric igniter, you need to locate where on the side of the grill the battery (e.g. AA size) that generates the electricity for the igniter is located. Replace the battery, and assure the contacts are cleaned (as they may have corrosion if grill located outside). Then check where the ground of the igniter is connected to the grill. I unscrewed the screw where the ground was located, cleaned off the corrosion with a fine sandpaper, then reconnected it to a new screw on the cabinet.
I have zanussi ZBS863 oven/grill but the grill not heating up as much as it used to and not cooking stuff properly, the outside part of grill still red but inside bar looks like it isn't working
It's a dual grill which uses the outside bar on full grill and /or oven. The innder is used on grill only. This part is open circuit and needs to be replaced.
Dec 07, 2009 • Ovens
I'm trying to replace thr grill ignitor on my Brinkmann 810-6320-B grill. There seems to be only one screw holding the part on the grill. I loosen the screw but it doesn't sseem to be coming out. Is there...
unscrew the starter like you are going to put a new battery in, there is a nut on the outside it will be black unscrew it and put the new one on
Jul 17, 2009 • Grilling
8helpful
2answers
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
52helpful
2answers
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
8helpful
5answers
Replace grill on 07 mustang
Follow this link to get instructions. I did and it worked for me. I also includes pictures of the process.
http://www.mustangmonthly.com/howto/mump_0710_center_grille_foglight_install/index.html
1helpful
2answers
Broken handle on a GGR50B grill
Hello: I just called 1-800-233-9054 and spoke to a customer relations person for George Foreman products. I was able to order a probe (electrical cord) for my George Foreman Outdoor Grill. I asked if that was the number to call for all parts and was told that it was. Give it a try. If I was able to order my part, I don't see why you wouldn't be able to also. Julie
Carrier 38CKC060 Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
shizznat
Level 1 Expert
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
