Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
How big is the ariston margherita awd12 washer drier
4 Related Answers
Anonymous
SOURCE: ariston margherita washer dryer awd12
To dry you need to turn the program to the little 'star' sign after the program 8 and not before. You then need to select the time you want the dryer on for, if you don't select a time the dryer doesn't come on...........not filling is a problem, it may be ythe electrics or it may be that there is something wrong with the door -if the machine thinks trhe door isn't closed it won't fill up but this machine generally uses a small amount of water and wil not actually fill up as such anyway......hope that helps!
M
x
Posted on Nov 21, 2007
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
Anonymous
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Anonymous
  • 6277 Answers
SOURCE: the filter wont unscrew,
Had the same problem with our Bosch, cap would not even turn!
Suggestions- (+ patience!)
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Posted on Apr 01, 2011
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
3helpful
We have the Ariston Margherita front loader washing machine and cannot get the door open
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
5helpful
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
18helpful
Thanks.
Ariston margherita washer dryer awd12
M
x
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Dan Webster
Dan Webster
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
