if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
Check the fuses.Blown fuse conditions FU1 - 6,3A Doors/covers open is displayed. FU2 - 6,3A Doors/covers open for the finisher is displayed. FU3 - 4A paper end condition. FU4 - 6,3A SC 121 is displayed. FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed. FU101 - 15A no response. Fu 102 - 8A no response. FU103 - 1A normal operation,optional heaters do not work. If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
You didn't list a model, and I assume that you mean "SC405". That relates to a transfer belt problem -probably the clutch, depending on the model. It will require a tech
