Question about Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer
The machine starts up fine runs slightly rough for about 10 secondary then smooths out and runs for about another 10 seconds and cuts off. It will restart fine the same way after about 5 seconds. Drained and replaced the year old gas and removed and checked the carb bowl no water. Oil was overfilled by previous owner so I drained down to proper level. What am I missing? ,Thanks
Posted by Robert Call on
sgtstrat
  • 34 Answers
Sounds like the carb is clogged with oil. Clean the carb and clean the fuel filter.
Posted on Jun 11, 2014
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Fuel system running rich and stalling
Sounds like it is slightly out of time.
Apr 14, 2014 | Ford Cars & Trucks
My 91 Chevy s-10 2 wheel drive p/u w/2.5 four cylinder wont idle and runs rough when i rev the motor which the only way i can keep it running is to feather the throttle. If i unplug the vacuum to the
the problem if from the map sensor.. when you change it it will run rough and keep cutting off,, keep stating it back and reeving over and over as soon as it cuts off again keep repeating until the CPU gets calibrated with the new sensor and it starts idling smoothly..
Dec 30, 2012 | 1991 Chevrolet S-10
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer Logo
393 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
