Question about Sony Audio Players & Recorders
Sony lbt-d707 I have a sony hifi set LBT-D707. Currently I have a tape in the left cassette player which I cannot get to open up so I can remove the tape. The button with which to open the cassette player is blocked halfway pressing (compared with the button for the right cassette player). How do I get this cassette player to open, so I can save my tape?
Posted by Frodo Wesseling on
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: MY SONY LBT-LX90AV CASSETT PLAYS DISCORD AND BELT FALLS OFF
Hi. Make sure the flywheel turns freely and that the capstan pin and pressure roller are clean. If this is OK then it is more than likely that the belt is stretched, dried out or generally worn. These parts only have a certain usable life and are quite cheap to replace.
Posted on Dec 23, 2008
nuwan chinth
nuwan chinthaka
  • 111 Answers
SOURCE: pushed power protect
speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Posted on Jan 12, 2009
Anonymous
SOURCE: sony lbt v702 hifi system stack
i have a sony stack system i had put away for a couple of years, i have now put it back together, but when i wire both speakers up, the sound go s to a point then cuts out, whith a mesage on the front saying protect, it i take one speaker off! nothing happens, can any one help please?
thak you for your time.
Steve.
Posted on Jan 26, 2010
jairo sanchez
  • 276 Answers
SOURCE: Hi, im looking for connecting
ment you can do there is make your own wire soldered on the inside of your computer by cable that there
Posted on Dec 05, 2010
caroldon
  • 17130 Answers
SOURCE: my sony LBT-ZUX10D midi hifi system disc tray
This can be due to many reasons and for a start you must be able to check the power to the loading motors, the loading drive IC's. If there is no input command to the IC,- check the voltages before eject , play is pressed and on rest.- to compare and confirm a input loss. If so the processor controller section is a suspect. Also if the mode settings are out of sync , the loading will not work.
Cannot rule out a damaged mechancial link, gear or drive. Need to start checking with all these tips after the mechanism is removed.
Take care with connectors and connections, make a note of your working so as not to forget the sections when fitting back.
Posted on Oct 08, 2011
Cassette drives will not play
You may have an issue with the cassette deck on your Sony LBT-D550. The cassette deck uses a belt drive system to operate the cassette mechanism; if belts are broken, it can cause the deck to malfunction.
All the belts may have failed at the same time, but it's also possible that there is another issue causing the problem. Some possible causes of a cassette deck malfunction include:
  • A problem with the cassette mechanism itself, such as a jammed cassette or worn-out gears.
  • A problem with the cassette deck's motor, which a malfunctioning capacitor or other components could cause.
  • A problem with the cassette deck's control board, which a malfunctioning switch or other components could cause.
To determine the cause of the problem, a professional technician should look at the cassette deck.
I have a sony lbt d550 cassette player that needs new belts. I need a picture of how to install the belts or how they are configured.
Below is a link for the service manual! The cassette dismantle is on page 9. from what I see there is a plate that covers access to the belts, that is if Your lucky! the plate is shown in the first picture on page 9, sorry I have worked on other brands, and some of them You have to do a lot of dismantling to even get to belts! Hope this helps You! Regards!
Sony HCD A295 HCD D550 LBT A295 LBT D550 Service Manual
I am looking for a complete owners manual for my Sony LBT D560 stereo player
You might try contacting Sony online chat at
What is your question Welcome to Sony Live Help
They may have a downloadable manual. Good luck.
1helpful
I have a remote which doesn't work anymore. (20 year old sony LBT-V502 hifi installation and it's standard RM-S530 remote.) What can I do? is it possible to buy a new one?
That is really old. Once you have tried fresh batteries there is not much more to do.
Amazingly there is one for auction on eBay. Good luck. Personally though, I would not buy it used at that price, I'd get a nice new hifi, maybe DAB radio,
http://www.ebay.co.uk/itm/Original-RM-S530-SONY-Remote-Control-Audio-system-for-HiFi-video-CD-Tuner-Tape-/200986250606?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item2ecbb6cd6e
Nov 11, 2013 • Cell Phones
I have a MJ D707 minidisc recorded discs reproduces them all well .the discs which have been recorded and deleted sometimes get error disc or disc broken, the next day he reads but records beaten to death,...
That is the most dizzying incomprehensible post I have ever seen!.
Just say what you want to say in English.
manual -- mypdfmanuals.com/user-manual,PIONEER,MJ-D707,1230701.pd
2helpful
Broken drive belt on cassette player lbt g2000 how
just go to a good electronics store i bought a pack of ten assorted belts today for $7.97 at **** Smith Electronics
7helpful
2answers
Finding an Instruction Manual for Sony stereo system
How do I remove the protect mode from my Sony LBT-LX5 Stereo?
Open Questions:
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
