Question about aFe 2001 Jeep Grand Cherokee - 4.0L 6-cyl. engine - Silver Bullet Throttle Body Spacers
01cherokee exhaust support
Need pic of exhaust pipe support brackets near trans crossmember
Posted by Bill J Pinkston on
Pic of starter on a 1989 Park avenue for replacement purposes
Gasoline Engines The starters on some engines require the addition of shims to provide proper clearance between the starter pinion gear and the flywheel. These shims are available in 0.015 in. (0.4mm) sizes from Buick, Oldsmobile and Pontiac dealers. Flat washers can be used if shims are unavailable.
  1. Important: disconnect the negative battery cable before proceeding.
  2. Raise the vehicle to a convenient working height and safely support it with jackstands.
  3. Remove the exhaust crossover pipe.
  4. Disconnect all wiring from the starter solenoid. Replace each nut as the connector is removed, as thread sizes differ from connector to connector. Tag the wires for later connection.
  5. Remove the flywheel housing cover and disconnect the oil cooler lines at the transmission, if necessary.
  6. Starter removal on certain models may necessitate the removal of the frame support. This support runs from the corner of the frame to the front crossmember. To remove:
    1. Loosen the mounting bolt that attaches the support to the corner of the frame.
    2. Loosen and remove the mounting bolt that attaches the support to the front crossmember and then swing the support out of the way.
    3. Install the crossmember and mounting bolts. Torque the bolts to 80 ft. lbs. (109 Nm).
  7. Remove the front bracket from the starter and the two mounting bolts. On engines with a starter solenoid heat shield, remove the front bracket upper bolt and detach the bracket from the starter.
  8. Remove the front bracket bolt or nut. Lower the starter front end first, then remove the unit from the vehicle.
  9. Installation is the reverse of removal. Make sure that any shims removed are replaced (please refer to the shimming procedure). Torque the two mounting bolts to 25-35 ft. lbs. (34-48 Nm). Connect the starter wires and install heat shields if removed.
Feb 22, 2015 | 1989 Buick Park Avenue
How to remove motor mounts on a 1992 lincoln
Remove the starter motor with a ratchet and socket and then unplug any electrical connectors from sensors or components attached to the transmission. Remove the sensors and components with a ratchet and socket.
Remove the header-exhaust pipe with a breaker bar and socket, if you believe you will need more room to secure and maneuver the transmission out of the vehicle.
Unfasten the transmission to mount, mount to crossmember and crossmember to frame bolts with a ratchet, ratchet extension and socket. Detach any brackets from the bell housing or rear of the transmission housing with a ratchet and socket. Secure the transmission with a transmission jack and raise the transmission just enough to remove the mount and crossmember supporting the transmission.
OEMScan GreenDS GDS 3 Professional Diagnostic Tool Support Online Update
Oct 17, 2014 | Cars & Trucks
I need to know where the drain plug is for a 2004 heritage....if you could send me a picture
on the right side of the bike, look down below the chrome end cap on the transmission on the frame. There is a hose with a steel plug in it or the hose plugs onto a crossmember of the frame. If it plugs onto the crossmember, look underneath that crossmember for the plug. I'm sure what year they move the drain. It's behind the exhaust pipes.
Good luck
Steve
Feb 04, 2011 | Harley Davidson FLSTC Heritage Classic...
I need to locate a service manual to remove and replace a plastic fuel tank with a metal one. Also for body/mirror and door replacements. Help--Thanks
  1. Release the fuel system pressure using the recommended procedure.
  2. Remove the fuel pump unit through the access panel in the floor of the trunk. Drain the fuel tank into a portable fuel siphoning container through the opening in the fuel tank where the fuel pump is mounted.
Prior to disconnecting fuel lines, wrap a shop rag around the connections to absorb any fuel spillage due to residual pressure in the lines.
  1. Disconnect negative battery cable.
  2. Raise and safely support the vehicle. Remove both rear tires.
  3. Remove the exhaust pipe rubber insulators off the mounting studs of the rear of the vehicle and in front of the fuel tank.
  4. Using grease pencil or paint marker, place alignment marks on the fuel filler hose, filler tube, vent hose and vent tube.
  5. Remove the rear splash shield from the right rear wheel well.
  6. Disconnect the fuel filler hose and the vent hose near the fuel filter.
  1. Disconnect both ends of the sway bar from the stabilizer links. Use a grease pencil or paint marker to outline the position of the crossmember ends on the frame rail.
  1. Remove the crossmember mounting bolts and pull the crossmember down until it stops.
  1. Place a transmission jack under the fuel tank to support its weight.
The sway bar bracket bolts must be replaced after loosening or removal. Only use original equipment bolts as replacement.
  1. Remove the sway bar mounting bracket, heat shield and fuel tank strap. To prevent the sway bar from falling down, install sway bar mounting bracket with the bolts finger-tight only.
  1. Carefully and slowly lower the front of the fuel tank. Slide the tank away from the crossmember while pushing the filler vent and fill tube over the crossmember. Detach any remaining fuel or electrical connections. Lower the fuel tank.
To install:
  1. Position the tank on the transmission jack or other suitable lift, with the shield and the tank strap in place. Raise the tank over the crossmember and place it in the proper position. Be sure that the electrical connector, pressure relief/rollover valve hose, fuel supply and return lines are accessible through the opening in the trunk. Check to be sure that nothing is pinched or kinked in any way.
  2. Push the vent and the filler tube over the crossmember. Rotate the sway bar into position and install the sway bar brackets.
  3. Raise the tank into place and position the sway bar mounting bracket and the tank straps in place. Tighten the bolts to 44 ft. lbs. (60 Nm).
  4. Raise the crossmember into position and align with the locating marks made during removal. Install bolts and tighten to 70 ft. lbs. (95 Nm).
  5. Reconnect the filler tube and vent tube making sure to align with the marks made during removal.
  6. Connect the sway bar ends to the link arms and tighten sway bar mounting nuts to 74 ft. lbs. (100 Nm).
  7. Install the exhaust onto the hangers. Install the rear splash shield in the right rear wheel well.
  8. Install the rear wheels and lug nuts. Tighten the lug nuts, in a star pattern sequence, to 95-100 ft. lbs. (129-135 Nm).
  9. Lower the vehicle.
  10. Install the fuel pump module.
  11. Connect the fuel supply, return and vent tubes. After installation of the quick-connect fittings, check for proper connection by pulling back on the quick-connect fitting. The tube should lock in place. If the connection is not complete, make sure the black plastic ring is not causing the locking retainer to jam in the release position.
  12. Install the fuel pump access cover and gasket. Tighten the fasteners and install the trunk liner.
  13. Install the filler cap and reconnect the negative battery cable.
  14. With the ignition in the ON position, access the DRB III ASD Fuel System Test to pressurize the fuel system. Check for leaks.
  1. Check the rear wheel alignment and adjust, if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 16, 2010 | 1994 Dodge Intrepid
Replaced transmission and now I have a traigle braket which I have no idea were it goes 4 holes on one side and one hole on the other
Can you post a pic of the bracket? The only triangular bracket I can think of on this install is on the drivers side of the crossmember. It goes on the bottom and the two thru bolts for the crossmember go thru the bracket.
Jul 12, 2010 | 1997 Chevrolet S-10 Pickup
Im trying to install bassani mid length headers for more power...whats involved in doing that..
yoy have to takke the h pipe down, take out mt . mount bolts trans crossmember bolts, drop h. pipe when you jack up engine you will havw to take steering loose from rack and pinon. push trans all the way over should give you enough room to do what you need to do.
Jun 16, 2010 | 1999 Ford Mustang Cobra
Where do we find the o2 sensor to replace it on 1996 ford explorer v-6 4.0
Item Part Number Description 1 52 Exhaust Inlet Pipe 2 N803420-S2 Exhaust Manifold-to-Inlet Pipe Bolts
(4 Req'd) 3 5E212 Three Way Catalytic Converter 4 5230 Muffler 5 N620482-S2 Exhaust Inlet Pipe-to-Converter Nut
(3 Req'd) 6 5B266 Exhaust Converter Inlet Pipe Gasket 7 N620481-S2 Nut 8 5E269 Exhaust Converter Frame Bracket 9 N620481-S2 Nut 10 5260 Exhaust Outlet Pipe Frame Bracket 11 5E269 Exhaust Converter Frame Bracket 12 39006 Screw and Washer 13 5E241 Exhaust Converter Outlet Gasket 14 5G215 Exhaust Pipe Flange Hold Down Spring 15 N802641-S2 Nut and Retainer 16 — Rear Heated Oxygen Sensor (HO2S) A — Tighten to 34-46 Nm
(25-34 Lb-Ft) B — Tighten to 20-25 Nm
(15-19 Lb-Ft) C — Tighten to 34-46 Nm
(25-34 Lb-Ft)
Apr 03, 2010 | 1996 Ford Explorer
How to take a manual transmission out of a chevy 1500
super easy even a novice mechanic can have one out in a little over an hour, lift it in the air about as high as you can get it put jack stands under it
disconnect the drive shaft
loosen the exhaust, doesnt need to come off
remove the starter
remove the slave cylinder
remove the shifter from the top 4 screws and 4x8mm bolts and 1x10mm bolt holding the wires running to the trans.
remove the bolts that connect the motor to the trans there are 6 really that hold it with several other nuts on top holding wires and such.
remove the 4 bolts that hold the crossmember and the bolt to the trans on the crossmember,
stick your jack underneath the trans and remove the crossmember. pull the trans straight back and lower. even without the right tools you can have this done in about 30min
Oct 18, 2009 | 1999 Chevrolet C1500
Torque settings on 2006 street glide
the clutch(derby) cover torque is 96 in lbs
the trans side cover is 120 in lbs.
Mar 30, 2009 | 2008 Harley Davidson FLHX Street Glide
aFe 2001 Jeep Grand Cherokee - 4.0L 6-cyl. engine - Silver Bullet Throttle Body Spacers Logo
686 people viewed this question
Top aFe Renewable Energy Experts
Ned Halaweh
Ned Halaweh
Vernon Taylor
Howie Snyder
Howie Snyder
Are you an aFe Renewable Energy Expert? Answer questions, earn points and help others
