Car Audio & Video Logo
Nain dpz Posted on Jun 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kenwood And every time I press eject bottom the display show demostration mode can't eject disc what should I do
colinjhought
Level 2:
  • Expert 126 Answers
  • Posted on Jun 10, 2014
colinjhought
Expert
Level 2:
Answers
126
Questions
0
Helped
51922
Points
381
Disconnect your car battery for a couple of minutes the unit has a constant power supply from your vehicle. This will allow the system to reset
1 Related Answer
Anonymous
  • 165 Answers
  • Posted on Mar 24, 2009
SOURCE: Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
My unit will not let me eject dvd disc it says it cant eject while in demonstration mode how do i shut the demo mode off
shut off the unit .press and hold for 30 seconds SRC and reset . then while pushing the SRC release the reset botton,hold it until the unit turns on and release it.
I tried it it worked well. (for Kenwood DDX7017 ).
tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
How Do I Set My Clock on My Kenwood KDC-MP208?
1:- Select Clock Adjustment mode Press the top or bottom side of the Control knob. Select the "ClK ADJ"/ "ClCK" display. 2:- Enter Clock Adjust mode. Press the centre of the Control knob for at least 1 second. The clock display blinks. 3:- Adjust the hours. Press the top or bottom side of the Control knob. Adjust the minutes Press the right or left side of the Control knob. 4:- Exit Clock adjustment mode, Press the [B.BOOST] button.
Now whats the time, Gotta get my tea.
Regards, Dave
My dvd player keeps saying it cannot eject disc cause it is in demostration mode. how do i get it out of this mode? steven jeffress
You will need to visit a Kenwood dealer (the dealer you purchased the unit from?) and they can assist you with that.
How to get it off demostration mode cd will not eject
only thing i can find out on your dvd player you should press the rest button when the unit fails to work proper it reset it back to factory setting
My kenwood ddx71017 is stuck in display mode and is not ejecting the disc. please help
Here's the pdf owners manual from kenwood. Try the reset button located on the right side of the kenwood logo. look at page 4 on this manual, good luck
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX7017.pdf
Try to eject cd and it displays 'demostration
hit the little reset button next to the kenwood logo on the bottom of the screen. Or go here...http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX8017.pdf
Disc does not eject on HDR UX7
Please press eject button and in same time press reset button.
In display you see "you sure open dvd case" and you answer is "yes".....
Disc eject on HDR-UX7 for me.....
Sanurax
2answers
Help
do u know the model number and brand
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
