Question about Cobra 19 DX IV CB Radio
I have a Cobra 19DXIV, it has been working fine with my "little Willy" antenna, but today on a job I was tranmitting fine but could not receive. The bar showed that someone was talking, but I could not hear. Any ideas?
Posted by Michael A Ruby on
wdes_151
    New Friend:
  • 7 Answers
Check squelch and wires to the speakers
Posted on Jul 03, 2014
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Posted on Dec 24, 2008
s60six
  • 328 Answers
SOURCE: cobra 25 ltd wx classic
the mics on these cobras have a receive wire in them so the transmit will still work even if the receive wire is broken,if this wire is broken the unit will not make any sound...........remove the plug from the radio end of the mic and check the connections on the 5 pin connector.....(could be a cold solder or broken wire) or try a new mic or one that is proven work on another radio
hope this helps.................good luck!
Posted on Dec 25, 2008
Anonymous
SOURCE: cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Posted on Jan 06, 2009
Anonymous
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Posted on Jan 07, 2009
Anonymous
  • 6966 Answers
SOURCE: cobra 142 gtl no audio on receive
Hi and welcome to FixYa,
Initially, the speaker of course has been checked?
Offhand, would partial schematic of the mic and speaker section help?
Good luck and thank you for asking FixYa.
Posted on Dec 20, 2009
How to increase the receive on a cobra 25ltd classic
1,if your antenna is not properly tuned you may be loosing receive as well as power 2,how your swr? 3 you may want to purchase a little driver with a built in receive amp.
Will not tranmitt
need more information but it could be a number of things.someone could have clipped the wrong diode to give it more modulation.Does it recieve at all? How about your antenna SWR , is it resonably low ? Is your power level low due to the tx problem?
2answers
How can I make the 19DXIV VHF capable
There is no way to make that radio VHF capable, CB radio's operate in the AM band, and most, if not all VHF radio's operate in the FM band. CB radio's are not capable of VHF frequencies either, VHF is considered around 40MHz and above, CB radio's operate between 26.965 MHz and 27.405MHz that is considered 11 meter band HF. CB radio's are not broadbanded enough to cover anything that far away, expecially the newer radio's, as most of them are controlled via a microcontroller and PLL tuning circuit. the 19DXIV is a great little radio, but will never be able to operate in or even around VHF. sorry.
How do I reset my Cobra 19DXIV CB radio to factory Settings
If you are ask that vague a question you should not open case. However that is your business.
pages 14, 15, 16 http://www.cbtricks.com/radios/cobra/19dx_iv/graphics/cobra_19dx_iv_sm.pdf
and of course all the tools listed in the link.
3helpful
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
3helpful
Tranmitting
one of the units may have a bad mic element. Can you hear the speaker unmute when the radio is keyed?
Cobra 19 DX IV CB Radio Logo
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
